查看: 145|回复: 13
PARKING AVAILABILITY STATUS.
 楼主| 发表于 2019-10-9 10:55:08 来自手机 | 显示全部楼层 |阅读模式
{"text":"If drivers are not going to physically get out, walk around, and \"take stock\" of available spots each night, then don't update the parking status.\n\n3 times the availability of the truck stop I'm at has been switched to \"Lot is Full\" when I was physically looking at 8 empty, EASY, and LEGAL spots.\n\nEvery night, I walk the lot I have shutdown in and update the availability with certainty. I don't guess!\n\nDon't be lazy! I take my time to be accurate because I like to know the actual chance I have to find a spot.","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-10-9 12:09:44 来自手机 | 显示全部楼层
{"replyTo":"","text":"If drivers can’t walk 10 feet to a garbage can... how on earth do you expect them to walk around a large parking lot?","replyToPid":0}
回复 支持 7 反对 0
发表于 2019-10-9 15:08:51 来自手机 | 显示全部楼层
{"replyTo":"","text":"Crowd sourcing parking availability is a stupid idea that will never work anyways. We need infrared depth sensing light sensors pointing over each parking spot and for it to automatically update immediately whether it’s open or occupied. Until we build this infrastructure, just don’t bother. I ignore it because it’s always going to be wrong and is ever changing. You never know when someone’s going to pull out. Just check it out for yourself, if full, on to the next truck parking spot till you find one. Just like we’ve always done. The sun will rise tomorrow. ","replyToPid":0}
发表于 2019-10-9 17:24:57 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"it's not always a lie.\ntrucks can come and go at anytime.  I've pulled into empty smaller rest areas only to see them nearly fill in 15 mins, then be nearly empty again 10 mins later.  just a bunch of drivers stopping to use the bathroom.  The rest area on i80 in Wyoming right at the Nebraska boarder is like this, it can go from empty to full and back to empty in under half an hour.\n\nit's also possible that a truckstop lot can be full then 5 mins later a bunch of drivers leave, or the opposite can happen.  a truckstop can have 10 spots available and withen 15 mins they get taken.\n\nweigh stations can actually close and open randomly based on traffic and inspections, that's not necessarily a lie either.  I've even seen weigh stations that only open to pull in trucks to inspect then close while doing the inspections."}
发表于 2019-10-9 11:45:49 来自手机 | 显示全部楼层
{"replyTo":"","text":"for real , I learned that quick . I dont even look at the parking status . people lie on it all the time .","replyToPid":0}
发表于 2019-10-12 10:41:29 来自手机 | 显示全部楼层
{"replyTo":"","text":"gotta love it when they update status during the day when everyone and there mother knows parking is available\ni hate it when the app asks during day","replyToPid":0}
发表于 2019-10-11 08:32:14 来自手机 | 显示全部楼层
{"replyTo":"","text":"Which is why u take it w/ a grain of salt. Take notes of the location you're passing through, check your hours available while looking at the local time you're at, & guess that what u see for parking availability could be right. It's not perfect but it's a start. \n\nBesides, anything after 6:30 PM local time, you're taking a chance at a truck stop. (Northeast: 4:30PM)","replyToPid":0}
发表于 2019-10-9 12:44:55 来自手机 | 显示全部楼层
{"replyTo":"","text":"Yeah that’s true don’t update if you’re inside the truck hate to do that unless I’m outside 😞","replyToPid":0}
发表于 2019-10-9 12:20:56 来自手机 | 显示全部楼层
{"replyTo":"","text":"Amen to that!","replyToPid":0}
发表于 2019-10-9 12:21:23 来自手机 | 显示全部楼层
747109 发表于 2019-10-09 03:45:49 for real , I learned that quick . I dont even look at the parking status . people lie on it all the time .
","text":"He lie about scale status as well","replyToPid":223963}
发表于 2019-10-9 13:21:39 来自手机 | 显示全部楼层
310244 发表于 2019-10-09 04:09:44 If drivers can’t walk 10 feet to a garbage can... how on earth do you expect them to walk around a large parking lot?
","text":"lol funnt but true","replyToPid":223968}
 楼主| 发表于 2019-10-10 14:12:52 来自手机 | 显示全部楼层
","text":"I know... way too much to hope for.","replyToPid":223968}
GMT+8, 2026-2-12 14:14 , Processed in 0.108940 second(s), 24 queries .
