查看: 107|回复: 3
Recap
 楼主| 发表于 2019-10-8 04:05:17 来自手机 | 显示全部楼层 |阅读模式
{"text":"Can someone explain HOS Recap’s please?","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-10-8 06:02:18 来自手机 | 显示全部楼层
{"replyTo":"","text":"When you have driven more then 8 days without a 70 hour reset. Each day you get more hours added to your 70 hour clock depending on how many hours you were on duty & driving 8 days ago. You also loose the amount you drive in the current day. Does that help? ","replyToPid":0}
发表于 2019-10-8 11:03:43 来自手机 | 显示全部楼层
{"replyTo":"","text":"basicly if u work perfect 8 hours shifts everyday ull never need a reset","replyToPid":0}
发表于 2019-10-13 21:55:40 来自手机 | 显示全部楼层
{"replyTo":"","text":"no need to worry about it. electronic logbook will tell you","replyToPid":0}
GMT+8, 2026-4-17 23:06 , Processed in 0.090063 second(s), 23 queries .
