查看: 140|回复: 4
Griping the wheel tight
 楼主| 发表于 2019-10-7 21:13:08 来自手机 | 显示全部楼层 |阅读模式
{"text":null,"videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":620.0,\"name\":\"\",\"url\":\"\",\"width\":828.0}]","canComment":true}
发表于 2019-10-7 22:29:50 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"Only one reason to drive with your high beams on all night.  You’re on a Dark two lane road with little traffic.  I’m amazed at how many people drive down an interstate with their high beams on.  "}
发表于 2019-10-7 22:00:07 来自手机 | 显示全部楼层
{"replyTo":"","text":"DRIVING TOOOOOO FAST! ! ! in dark and spooky nights slow the F down! ! human brain is designed for running full speed at night 5 miles per hour sustained! proper head lights get you to that 55 mph line! ! NOT 75-85 mph! alllll the time every time every blasted night! !  ","replyToPid":0}
发表于 2019-10-7 23:35:23 来自手机 | 显示全部楼层
649838 发表于 2019-10-07 14:29:50 Only one reason to drive with your high beams on all night.  You’re on a Dark two lane road with little traffic.  I’m amazed at how many people drive down an interstate with their high beams on.
","text":"Personally I find if there is a wide centre median 80-100 feet wide it doesn’t bug me. \n\nBut no need for a light bar. Unless I’m in the mountains it stays off. \n\nOr need to teach a lesson in courtesy ","replyToPid":222898}
发表于 2019-10-7 22:01:12 来自手机 | 显示全部楼层
{"replyTo":"","text":"that's a damn good question. same with all the super bright light bars. if you can't see don't drive. pretty simple solution to a not so complicated problem.","replyToPid":0}
GMT+8, 2026-4-19 09:52 , Processed in 0.071428 second(s), 24 queries .
