查看: 227|回复: 6
Endorsements
 楼主| 发表于 2019-10-7 12:57:01 来自手机 | 显示全部楼层 |阅读模式
{"text":"Is having Hazmat or Dbls really worth all the hype?","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-10-7 22:04:34 来自手机 | 显示全部楼层
{"replyTo":"","text":"there is no hype but having endorsements along with twic and passport will take your career a lot further than not having them. either way it's up to you kid.","replyToPid":0}
发表于 2019-10-7 21:31:02 来自手机 | 显示全部楼层
{"replyTo":"","text":"In my experience, yes. Even in dry van I had an advantage over most other drivers and got higher paying loads at times and more miles. It depends on your company and their freight pool. ","replyToPid":0}
发表于 2019-10-7 21:42:52 来自手机 | 显示全部楼层
{"replyTo":"","text":"Why get one the loads don’t pay anymore than regular load so why go thru all the hassle ","replyToPid":0}
发表于 2019-10-7 20:40:34 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"no, not really. those loads are toxic. tanker is the only one I use. I have never used my twic card."}
发表于 2019-10-7 20:00:03 来自手机 | 显示全部楼层
{"replyTo":"","text":"If you’re in dryvan yes and a twic card is worth it to keep you moving I’d get the tanker to. D/T and haz not really used in flatbed but  I do use tanker and haz more often than I imagined ","replyToPid":0}
发表于 2019-10-16 21:47:50 来自手机 | 显示全部楼层
{"replyTo":"","text":"personally I'd say yes. the more you can haul the less likely you'll get a crappy load and the more valuable you are to a company","replyToPid":0}
GMT+8, 2026-4-17 23:06 , Processed in 0.111912 second(s), 24 queries .
