查看: 337|回复: 16
Does anyone else twist their straps on certain loads like this?🤔I was told its better than throwing them straight across
 楼主| 发表于 2019-10-7 07:52:59 来自手机 | 显示全部楼层 |阅读模式
{"text":null,"videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":1216.0,\"name\":\"\",\"url\":\"\",\"width\":828.0}]","canComment":true}
发表于 2019-10-7 08:02:22 来自手机 | 显示全部楼层
{"replyTo":"","text":"Yes. It keeps the straps from vibrating and flapping in the wind and making that buzzing or popping sound. A half twist is all it takes.","replyToPid":0}
回复 支持 9 反对 0
发表于 2019-10-7 09:00:51 来自手机 | 显示全部楼层
827022 发表于 2019-10-07 00:38:29 Oh ok so is it only good for high loads? Because when I have shiny bar I don’t do that
","text":"And the edges of your straps dont get frayed if they're not vibrating in the wind.","replyToPid":222602}
发表于 2019-10-7 11:37:35 来自手机 | 显示全部楼层
{"replyTo":"","text":"a half if a twist keeps the straps from vibrating without overtightening. it's a great practice on material that is soft.","replyToPid":0}
发表于 2019-10-7 10:16:18 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"If im doing generic steel lengths(pipe, sucker rods, beams, etc) its straight and tight as I can put it.  If it does more than vibrate, starting to flap a little, then its load check time.\n\nIf I got PVC or other stuffs I can crush, it gets a twist.  Tall loads, even if steel, get a twist (shipping containers, for instance).  Nothing like hearing strap slap steel continously until the cargo gets a band of color from the straps."}
 楼主| 发表于 2019-10-7 08:38:29 来自手机 | 显示全部楼层
190599 发表于 2019-10-07 00:02:22 Yes. It keeps the straps from vibrating and flapping in the wind and making that buzzing or popping sound. A half twist is all it takes.
","text":"Oh ok so is it only good for high loads? Because when I have shiny bar I don’t do that","replyToPid":222568}
发表于 2019-10-7 20:26:27 来自手机 | 显示全部楼层
{"replyTo":"","text":"I only did it on tall fragile loads, styrofoam, PVC ect. If it's anything else, you can get flat straps on ridged loads much tighter so long as you tighten them down good, they won't flap.","replyToPid":0}
发表于 2019-10-7 20:50:55 来自手机 | 显示全部楼层
{"replyTo":"","text":"Yes absolutely.No flapping in the wind.","replyToPid":0}
发表于 2019-10-7 10:38:14 来自手机 | 显示全部楼层
{"replyTo":"","text":"Always. It keeps them from flapping. ","replyToPid":0}
发表于 2019-10-7 08:08:38 来自手机 | 显示全部楼层
{"replyTo":"","text":"Hey..I’ve twisted my straps when was doing flatbed..","replyToPid":0}
发表于 2019-10-7 08:01:49 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"sometimes twisted strap help tighten the load better"}
发表于 2019-10-7 08:07:22 来自手机 | 显示全部楼层
{"replyTo":"","text":"Looks good to me ","replyToPid":0}
发表于 2019-10-7 08:59:11 来自手机 | 显示全部楼层
{"replyTo":"","text":"Youre exactly right. It helps a lot with the higher loads. There's not as much strap surface getting hit by wind on the shorter stuff.","replyToPid":0}
GMT+8, 2026-2-12 16:00 , Processed in 0.065948 second(s), 24 queries .
