查看: 74|回复: 3
Carrier 2100A
 楼主| 发表于 2019-10-7 02:51:23 来自手机 | 显示全部楼层 |阅读模式
{"text":"I got a problem. It is doing defrosting very often. After working hard to reach a certain temperature. Is this normal?  ","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-10-7 10:58:44 来自手机 | 显示全部楼层
{"replyTo":"","text":"Likely low on freon. Coils are icing up.","replyToPid":0}
发表于 2019-10-7 11:51:51 来自手机 | 显示全部楼层
{"replyTo":"","text":"We had this kind of issue on a Thermoking because the load was too warm... but maybe that’s no5 the case here ","replyToPid":0}
发表于 2019-10-7 20:22:40 来自手机 | 显示全部楼层
{"replyTo":"","text":"try cleaning condenser   \npossible  low freon  \nsome load will wreck havoc  on reefer temps  also","replyToPid":0}
GMT+8, 2026-4-17 21:24 , Processed in 0.109094 second(s), 23 queries .
