查看: 181|回复: 10
Do you believe
 楼主| 发表于 2019-10-7 02:31:18 来自手机 | 显示全部楼层 |阅读模式
{"text":"That staying precautious is more dangerous than being relaxed? I had this buddy of mine that says that if you are more precautious, there is a higher chance of commiting a mistake  ","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-10-7 11:05:00 来自手机 | 显示全部楼层
{"replyTo":"","text":"if your precautious about things you gonna end up doing your job very well","replyToPid":0}
发表于 2019-10-7 15:37:06 来自手机 | 显示全部楼层
{"replyTo":"","text":"Neither. My advice is to stop overthinking it and just drive safely and comfortably. ","replyToPid":0}
发表于 2019-10-7 06:43:49 来自手机 | 显示全部楼层
{"replyTo":"","text":"I disagree ","replyToPid":0}
发表于 2019-10-7 10:56:50 来自手机 | 显示全部楼层
{"replyTo":"","text":"You can be cautious without being all tensed up. Be awake, alert, and ready.  But don't stress out over what COULD happen. Just know that it CAN. Be prepared enough to avoid it if and when it does. Defensive maneuvers are difficult when you have a death grip on the steering wheel.","replyToPid":0}
发表于 2019-10-7 13:20:00 来自手机 | 显示全部楼层
829740 发表于 2019-10-07 05:17:23 being over cautious I think helps cause a mistake
","text":"🤔🤔🤔🤔","replyToPid":222753}
发表于 2019-10-7 13:17:23 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"being over cautious I think helps cause a mistake"}
发表于 2019-10-7 08:26:50 来自手机 | 显示全部楼层
{"replyTo":"","text":"That is possibly the worst advice ever. \nSounds more like an excuse not to do his job and some warped rationale for his laziness. I doubt it would hold up in a court of law.","replyToPid":0}
发表于 2019-10-7 11:05:06 来自手机 | 显示全部楼层
{"replyTo":"","text":"🤔🤔🤔","replyToPid":0}
发表于 2019-10-7 13:20:12 来自手机 | 显示全部楼层
613661 发表于 2019-10-07 03:05:00 if your precautious about things you gonna end up doing your job very well
","text":"absolutely right","replyToPid":222676}
发表于 2019-10-7 13:43:37 来自手机 | 显示全部楼层
{"replyTo":"","text":"Over cautious isn't a good thing.\nThere is a fine line you must learn... between relaxed / cautious and alert / prepared.\nNew drivers often tend to be tense/cautious then evolve to relaxed and cautious.\nEventually, as time goes by you'll find yourself in the zone where you are alert and prepared.","replyToPid":0}
GMT+8, 2026-4-17 21:23 , Processed in 0.102006 second(s), 24 queries .
