查看: 102|回复: 8
Bunk heater
 楼主| 发表于 2019-10-6 20:44:25 来自手机 | 显示全部楼层 |阅读模式
{"text":"Can anyone tell me how to clean the screen and igniter on a 2013 Peterbilt 386 bunk heater? ","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-10-6 23:59:59 来自手机 | 显示全部楼层
{"replyTo":"","text":"Is it espar heater","replyToPid":0}
发表于 2019-10-7 01:41:36 来自手机 | 显示全部楼层
{"replyTo":"","text":"Have you tried searching the information on Google?","replyToPid":0}
 楼主| 发表于 2019-10-7 02:44:10 来自手机 | 显示全部楼层
{"replyToPid":222194,"replyTo":"","text":"Espar "}
 楼主| 发表于 2019-10-7 02:44:21 来自手机 | 显示全部楼层
679939 发表于 2019-10-06 17:41:36 Have you tried searching the information on Google?
","text":"Yes I have I cannot find anything","replyToPid":222271}
发表于 2019-10-7 06:09:46 来自手机 | 显示全部楼层
{"replyTo":"","text":"well im glad you ask. i had to do this once. what you do is get a lighter,some gasoline (premium) and pour it all under that bunk. then light a newspaper. and throw it under there. and watch the magic.","replyToPid":0}
发表于 2019-10-7 06:14:18 来自手机 | 显示全部楼层
 楼主| 发表于 2019-10-7 07:50:10 来自手机 | 显示全部楼层
{"replyToPid":222527,"replyTo":"
752131 发表于 2019-10-06 22:09:46 well im glad you ask. i had to do this once. what you do is get a lighter,some gasoline (premium) and pour it all under that bunk. then light a newspaper. and throw it under there. and watch the magic.
","text":"Solved.. bad connection was making it shut down.. removed connector and wired direct.. no more problem. Donald Trump your suggestion was next! "}
发表于 2019-10-8 04:15:38 来自手机 | 显示全部楼层
766319 发表于 2019-10-06 23:50:10 Solved.. bad connection was making it shut down.. removed connector and wired direct.. no more problem. Donald Trump your suggestion was next!
","text":"Im glad i can be a helpful. have a blessed day.","replyToPid":222563}
GMT+8, 2026-2-13 13:03 , Processed in 0.069154 second(s), 23 queries .
