查看: 195|回复: 14
Oh! my word!!!😂😂😂😂
 楼主| 发表于 2019-10-6 14:34:59 来自手机 | 显示全部楼层 |阅读模式
{"text":"","videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":960.0,\"name\":\"\",\"url\":\"\",\"width\":714.0}]","canComment":true}
发表于 2019-10-6 20:37:27 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"I would not think that would even be possible. You would think the rear tandem would be enough to offset the weight. A tanker usually has about 9000 gallons of fuel which is roughly 55,000 pounds so it would be hard to get 5000 gallons in the very front of the landing gear. "}
发表于 2019-10-6 21:45:16 来自手机 | 显示全部楼层
{"replyTo":"","text":"lol... so you think the tandems are going to outweigh that amount of fuel...you must be a swift driver","replyToPid":0}
发表于 2019-10-6 22:46:24 来自手机 | 显示全部楼层
{"replyToPid":222162,"replyTo":"
553650 发表于 2019-10-06 13:45:16 lol... so you think the tandems are going to outweigh that amount of fuel...you must be a swift driver
","text":"If you think you can put 5000 gallons of fuel in the nose of the tanker in front of the landing gear then you are the swift driver.. The tanker is 48 foot long and hauls 9000 gallons of fuel, divide 9000 by 48×7.1 pounds per gallon times the length from the landing gear to the nose and you will easily see it’s not possible for this to happen. Let me help you, that’s about 1331 pounds per foot With lets just say about 10 foot of tanker in front of the landing gear which is going to give you about 13,000 pounds. Do you have any idea how much your rear tandem weighs.. I know you Swift drivers usually don’t scale or have any ideal about weights on your trucks but before calling someone else a swift driver at least research"}
发表于 2019-10-6 23:04:40 来自手机 | 显示全部楼层
","text":"Well to start with no one ever said the rear tandem weighed more than 5000 gallons of fuel. You did not read the reply you just assumed","replyToPid":222162}
发表于 2019-10-7 01:03:40 来自手机 | 显示全部楼层
766319 发表于 2019-10-06 12:37:27 I would not think that would even be possible. You would think the rear tandem would be enough to offset the weight. A tanker usually has about 9000 gallons of fuel which is roughly 55,000 pounds so it would be hard to get 5000 gallons in the very front of the landing gear.
","text":"that's true ! 5000 gallon won't fit infront of landing gear . so it can not drop down like that.  plus tank manufacturers would not make a tanker like that.  it's fake","replyToPid":222133}
发表于 2019-10-7 02:22:22 来自手机 | 显示全部楼层
{"replyTo":"","text":"Most fuel tankers only hold 3000 gallons in the front compartment. ","replyToPid":0}
发表于 2019-10-7 02:26:53 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"Also, yes, this can happen. The proper way to haul fuel is to empty the rear compartment first to keep the trailer from handling ‘squirrelly,” and if the front compartment is full and the others aren’t, it can tip over, which is why you’re not supposed to unhook from it, but have it towed. The company should have known this. "}
发表于 2019-10-7 02:50:13 来自手机 | 显示全部楼层
497499 发表于 2019-10-06 18:26:53 Also, yes, this can happen. The proper way to haul fuel is to empty the rear compartment first to keep the trailer from handling ‘squirrelly,” and if the front compartment is full and the others aren’t, it can tip over, which is why you’re not supposed to unhook from it, but have it towed. The company should have known this.
","text":"Well if the front compartment holds 3000 gallons and the entire tanker holds 9000 then the front compartment must be 16 foot so that would go over the top of the landing gear and the weight should be distributed evenly enough for that not to happen. ","replyToPid":222298}
发表于 2019-10-7 02:54:02 来自手机 | 显示全部楼层
766319 发表于 2019-10-06 18:50:13 Well if the front compartment holds 3000 gallons and the entire tanker holds 9000 then the front compartment must be 16 foot so that would go over the top of the landing gear and the weight should be distributed evenly enough for that not to happen.
","text":"You would think so, and some fuel tanker manufacturers do think of this. When I hauled fuel out of Nashville, one of our tankers tipped over like this though. The front compartment as full and the others were empty. ","replyToPid":222340}
GMT+8, 2026-2-12 09:15 , Processed in 0.077780 second(s), 23 queries .
