查看: 291|回复: 17
question
 楼主| 发表于 2019-10-6 07:59:19 来自手机 | 显示全部楼层 |阅读模式
{"text":"have you ever been pulled over in California for speeding when a vehicle pulling a Uhaul trailer is passing you ","videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":376.0,\"name\":\"\",\"url\":\"\",\"width\":271.0}]","canComment":true}
发表于 2019-10-6 11:40:01 来自手机 | 显示全部楼层
{"replyTo":"","text":"Uhaul driver usually lacks enough money to live in Commiefornia, much less pay that ticket.  The ones pulling a boat behind the RV have the money, but it isn't a commercial vehicle with jacked up fines.  The CMV on the otherhand is a rolling ATM just begging to for constant use.","replyToPid":0}
发表于 2019-10-6 22:39:02 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"Not yet.  I've had cops pass me while I was doing 65-70.  Was one time on a 2 lane I moved over and sped up to 70 to pass a slow moving truck up a hill and even then the cop behind me didn't pull me over, just turned on his lights when I was clear to make me move back over so he could pass and continue down the road.\n\nThe cops probably don't like that speed limit either, they'd probably prefer seeing trucks keep up with traffic instead of basically being rolling road blocks slowing down traffic."}
发表于 2019-10-6 15:46:39 来自手机 | 显示全部楼层
{"replyTo":"","text":"I was pulled over and told the officer the truth. I was singing my playlist and sometimes it’s difficult to determine your speed at night when the road seems flat and not continuously looking at my speedometer. He let me go. No joke","replyToPid":0}
发表于 2019-10-6 13:00:27 来自手机 | 显示全部楼层
{"replyTo":"","text":"I don’t spend too much time in Cali, but when I do, I’m usually going 63.","replyToPid":0}
发表于 2019-10-7 04:28:29 来自手机 | 显示全部楼层
{"replyTo":"","text":"Singing \"I can't drive 55\" by Van Hagar?","replyToPid":0}
发表于 2019-10-7 04:02:50 来自手机 | 显示全部楼层
756043 发表于 2019-10-06 04:45:50 hate that speed limit....
","text":"Hate that state ","replyToPid":222037}
发表于 2019-10-6 18:59:02 来自手机 | 显示全部楼层
{"replyTo":"","text":"Actually an RV does not require a CDL.","replyToPid":0}
发表于 2019-10-6 12:45:50 来自手机 | 显示全部楼层
{"replyTo":"","text":"hate that speed limit.... ","replyToPid":0}
发表于 2019-10-6 11:48:09 来自手机 | 显示全部楼层
{"replyTo":"","text":"They rather pull over the truck driver as it’s a higher fine. ","replyToPid":0}
发表于 2019-10-6 13:13:05 来自手机 | 显示全部楼层
{"replyTo":"","text":"doesn't matter what you're driving if you have the cdl when you're pulled over you can get the same ticket and the RV requires a CDL in most case only a class B or C.","replyToPid":0}
发表于 2019-10-7 00:07:15 来自手机 | 显示全部楼层
{"replyTo":"","text":"All depends on the cop... I’ve known drivers get pulled over for doing 60.","replyToPid":0}
GMT+8, 2026-4-18 18:42 , Processed in 0.109287 second(s), 24 queries .
