查看: 184|回复: 15
RIP off
 楼主| 发表于 2019-10-6 03:46:12 来自手机 | 显示全部楼层 |阅读模式
{"text":"11.00 for 2.5gals...isnt this stuff 90% water anyway???😡🤬","videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":2016.0,\"name\":\"\",\"url\":\"\",\"width\":1512.0}]","canComment":true}
发表于 2019-10-6 11:28:40 来自手机 | 显示全部楼层
{"replyTo":"","text":"Not as much as you're buying it in bulk. \n\nProbably get more for the same price if u pump it straight from the fuel island. 🤔","replyToPid":0}
发表于 2019-10-6 08:34:32 来自手机 | 显示全部楼层
{"replyTo":"","text":"If you use enough of it.. it will “burn” your lawn.","replyToPid":221898}
发表于 2019-10-6 03:52:11 来自手机 | 显示全部楼层
{"replyTo":"","text":"Cheaper than Roundup.\n\nKills just as good.","replyToPid":0}
发表于 2019-10-6 03:53:40 来自手机 | 显示全部楼层
{"replyTo":"","text":"Walmart is the cheapest on that cräp about $8 bucks","replyToPid":0}
发表于 2019-10-6 03:54:54 来自手机 | 显示全部楼层
{"replyTo":"","text":"$11 isn't that bad try buying it at pilot and it's like $15","replyToPid":0}
发表于 2019-10-6 07:59:54 来自手机 | 显示全部楼层
{"replyTo":"","text":"It is mainly composed of urea- the same compound in pee. That’s why the DEF pumps smell like piśś. ","replyToPid":0}
发表于 2019-10-6 09:15:43 来自手机 | 显示全部楼层
{"replyTo":"","text":"🖕TP","replyToPid":221934}
发表于 2019-10-6 11:16:29 来自手机 | 显示全部楼层
{"replyTo":"","text":"Last I remember, its 2/3rds water, 1/3rds urea.  Freezes at 12 degrees farenheit.","replyToPid":0}
发表于 2019-10-6 11:20:16 来自手机 | 显示全部楼层
{"replyTo":"","text":"I mix mine with 50% water. good to 20 degrees.","replyToPid":0}
GMT+8, 2026-2-12 09:15 , Processed in 0.103064 second(s), 24 queries .
