查看: 150|回复: 4
Straight pipes vs stacks
 楼主| 发表于 2019-10-6 01:31:24 来自手机 | 显示全部楼层 |阅读模式
{"text":"So what is the difference between straight pipes and stacks, or is there no difference?  ","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-10-6 11:33:07 来自手机 | 显示全部楼层
{"replyTo":"","text":"Apples and oranges...  Straight pipes is running without muffler/emissions, where they are either missing or modified (core removed); loud.\n\nStacks are usually referring to the vertical exhaust stacks that run either behind the cab or just behind the B pillars. Your typical  Weedburning freightliner cascadia has no stacks, per se, just a fat horizontal tailpipe near the drive shaft.","replyToPid":0}
发表于 2019-10-6 10:27:29 来自手机 | 显示全部楼层
{"replyTo":"","text":"There is no difference ","replyToPid":0}
发表于 2019-10-6 13:39:18 来自手机 | 显示全部楼层
{"replyTo":"","text":"Cows and puppy’s. ","replyToPid":222006}
发表于 2019-10-6 23:19:35 来自手机 | 显示全部楼层
{"replyTo":"","text":"Single stack Mack with a window in the back.","replyToPid":0}
GMT+8, 2026-4-17 23:06 , Processed in 0.159510 second(s), 24 queries .
