查看: 244|回复: 19
Pros and cons
 楼主| 发表于 2019-10-5 23:20:50 来自手机 | 显示全部楼层 |阅读模式
{"text":"I’m a company driver. My truck doesn’t have a refrigerator I’ve been contemplating getting one of these Coleman coolers. Does anyone have one? and if so what are the pros and cons of this cooler?","videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":896.0,\"name\":\"\",\"url\":\"\",\"width\":414.0}]","canComment":true}
发表于 2019-10-5 23:39:20 来自手机 | 显示全部楼层
{"replyTo":"","text":"Agreed. Decent unit.\n\nMy only issue was the 12V plug in. Kept melting. Had to replace it numerous times.\n\nAnd it’s not meant for continuous use, as in 24/7/365. Taking it for the weekend, sure. But over the road wears it out. If you get 2 years out of it, you’re doing good, IMO.","replyToPid":0}
发表于 2019-10-6 04:00:15 来自手机 | 显示全部楼层
{"replyTo":"","text":"they aren't bad of you go home frequently but if your gonna stay out like 2 or 3 months at a time i would say try to get a real fridge. if you get this style when you replace the plug try and find one with a  fuse built in like a normal car fuse I used it and swapped the fuse out for a lower rated one only ever replaced my plug once I did that replaced the fuse every 6months or so","replyToPid":0}
发表于 2019-10-6 00:04:26 来自手机 | 显示全部楼层
{"replyTo":"","text":"like said before if continously used won't last very long. Walmart has 2 real mini fridges for 75 and 99 dollars. I have both, the 99 is better but bigger. The 75 is perfect for 1 week of food. Just strap to the top bunk and you're good to go.","replyToPid":0}
发表于 2019-10-6 05:59:27 来自手机 | 显示全部楼层
{"replyTo":"","text":"Avoid these coolers and just get a real mini fridge and a hi wattage inverter. These coolers only keep the interior around 40 degrees colder than ambient temperature. They aren’t equipped with thermostats so you can’t control it. I’ve had milk and water freeze solid and food spoil :/ ","replyToPid":0}
发表于 2019-10-7 10:10:11 来自手机 | 显示全部楼层
794398 发表于 2019-10-07 00:52:47 dometic is the best and almost 1000 dollars but the best ever
","text":"Dometic has a unit for less than $500... maybe not as large, but works great!","replyToPid":222605}
发表于 2019-10-6 03:57:07 来自手机 | 显示全部楼层
599477 发表于 2019-10-05 18:45:41 It’s not a real fridge though, right? Can’t really hold actual cold temperatures?
","text":"it not a real fridge but I have frozen things in there.","replyToPid":221679}
发表于 2019-10-6 01:50:07 来自手机 | 显示全部楼层
{"replyTo":"","text":"Check out “Dometic”","replyToPid":0}
发表于 2019-10-6 02:19:21 来自手机 | 显示全部楼层
{"replyTo":"","text":"I Had One When I First Started, I Loved It. Mine Was Continuous Use, It Lasted Me 3 Yrs","replyToPid":0}
发表于 2019-10-5 23:29:29 来自手机 | 显示全部楼层
{"replyTo":"","text":"hey when I first started driving I had bought me one of these coolers and they're actually not quite bad they're very roomy so you'll be able to fit quite a lot of stuff out there","replyToPid":0}
发表于 2019-10-6 00:32:28 来自手机 | 显示全部楼层
{"replyTo":"","text":"hey i got mine for sale..only used 2mths. still new. i bought my own truck and has fridge installed.so let me know if anyone wants to buy??","replyToPid":0}
发表于 2019-10-6 01:03:50 来自手机 | 显示全部楼层
{"replyTo":"","text":"the plugs do melt after some time ive heard but i know people who have them not bad to start i guess.i have 1500 watt inverter and been wanting a walmart real mini fridge asap","replyToPid":0}
发表于 2019-10-6 02:45:41 来自手机 | 显示全部楼层
{"replyTo":"","text":"It’s not a real fridge though, right? Can’t really hold actual cold temperatures?","replyToPid":0}
GMT+8, 2026-2-6 05:39 , Processed in 0.114773 second(s), 24 queries .
