查看: 164|回复: 2
Kw t680 2015, adaptive cruise fault anyone has had this problem
 楼主| 发表于 2019-10-5 21:30:41 来自手机 | 显示全部楼层 |阅读模式
{"text":"youtu.be","videos":"[]","link":"{\"picture\":{\"description\":\"\",\"height\":180.0,\"name\":\"\",\"url\":\"https://img.youtube.com/vi/peP5krxZaUM/mqdefault.jpg\",\"width\":320.0},\"title\":\"YouTube\",\"type\":\"VIDEO\",\"url\":\"https://youtu.be/peP5krxZaUM\",\"valid\":true}","pics":"[]","canComment":true}
发表于 2019-10-5 22:23:57 来自手机 | 显示全部楼层
{"replyTo":"","text":"Yep mine is a 2016. It’s caused from the sensor in the front of truck. I had a loose wire that was fixed and it went away ","replyToPid":0}
发表于 2019-10-6 06:03:16 来自手机 | 显示全部楼层
{"replyTo":"","text":"I’ve found mine stops working sometimes in freezing temperatures. I just pull off and give it a good cleaning and it’s good to go again. ","replyToPid":0}
GMT+8, 2026-3-21 05:56 , Processed in 0.083781 second(s), 24 queries .
