查看: 305|回复: 8
Trip Planning
 楼主| 发表于 2019-10-4 09:27:03 来自手机 | 显示全部楼层 |阅读模式
{"text":"Can some of you long timers, give some of these new timers some planning advice? ","videos":"[]","link":"{}","pics":"[]","canComment":true}
 楼主| 发表于 2019-10-4 09:36:19 来自手机 | 显示全部楼层
682141 发表于 2019-10-04 01:31:00 truckmiles.com if you don't have a good gps
","text":"I use a garmin but I also use my atlas to make sure my GPS doesnt send me somewhere I'm not allowed. I also only plan 600 miles a day if I'm running a 65 mph truck, if I can do more great, but if not then I'm not screwed on delivery times.","replyToPid":220580}
回复 支持 3 反对 2
发表于 2019-10-4 15:09:17 来自手机 | 显示全部楼层
{"replyTo":"","text":"I always trip plan at the industry standard 50 mph and add an hr a day for fuel/scale and 30 minute break. Then for live load/unload I add at least 2 hrs per live stop. For drop/hooks I add 1 hr. ","replyToPid":0}
回复 支持 2 反对 2
 楼主| 发表于 2019-10-5 06:16:13 来自手机 | 显示全部楼层
791878 发表于 2019-10-04 20:37:20 Time things out. \n\nHitting a major city during rush hour. Plan for that. \n\nPlan to shut down early. If where you plan to park is full go to the next one. \n\nWhen my eld says I got 1 hr left I’ll use that time to find a spot.
","text":"I made it thru san antonio early early this am and took my fuel stop/30 min break/an hour nap to let Houston die down on rush hour and it was pretty smooth sailing aside from construction and an accident. and tomorrow I'll make it thru Tallahassee and Gainesville before any traffic. hopefully I'll miss any of the college football traffic.","replyToPid":221075}
发表于 2019-10-4 11:05:00 来自手机 | 显示全部楼层
{"replyTo":"","text":"I plan everything at 50 mph so I also have extra time I'm governed at 70 so I'm over cautious. 600 miles a day is good for those days to get to drive full clock but when you got a delivery and a pickup your plans are always changing.\n\nI keep my dash clear and windshield and headlights clean. also if you keep your curtains to the bunk open DOT tends to leave you alone more, if you're a solo driver. obviously if you're a team and have the stickers then its understood why the curtains are closed.","replyToPid":0}
 楼主| 发表于 2019-10-5 06:18:29 来自手机 | 显示全部楼层
{"replyTo":"","text":"ooh that's another thing, keep up on sporting events like football, basketball, nascar, etc and any major concerts that might effect the traffic where you are going. Check weather reports and plan for the weather ahead. You cant use cruise control if it's bad weather.","replyToPid":0}
发表于 2019-10-4 09:31:00 来自手机 | 显示全部楼层
{"replyTo":"","text":"truckmiles.com if you don't have a good gps","replyToPid":0}
发表于 2019-10-5 06:18:23 来自手机 | 显示全部楼层
782997 发表于 2019-10-04 22:16:13 I made it thru san antonio early early this am and took my fuel stop/30 min break/an hour nap to let Houston die down on rush hour and it was pretty smooth sailing aside from construction and an accident. and tomorrow I'll make it thru Tallahassee and Gainesville before any traffic. hopefully I'll miss any of the college football traffic.
","text":"See. Your getting the hang of it. \n\nAlways try and think ahead. ","replyToPid":221120}
发表于 2019-10-5 04:37:20 来自手机 | 显示全部楼层
{"replyTo":"","text":"Time things out. \n\nHitting a major city during rush hour. Plan for that. \n\nPlan to shut down early. If where you plan to park is full go to the next one. \n\nWhen my eld says I got 1 hr left I’ll use that time to find a spot. ","replyToPid":0}
GMT+8, 2026-4-17 19:43 , Processed in 0.093348 second(s), 24 queries .
