查看: 154|回复: 3
This is quite helpful
 楼主| 发表于 2019-10-4 04:59:48 来自手机 | 显示全部楼层 |阅读模式
{"text":"Knew some of them","videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":1104.0,\"name\":\"\",\"url\":\"\",\"width\":828.0}]","canComment":true}
发表于 2019-10-4 09:15:59 来自手机 | 显示全部楼层
{"replyTo":"","text":"The Laundress products from Amazon are badass for all stains.","replyToPid":0}
发表于 2019-10-4 07:00:22 来自手机 | 显示全部楼层
{"replyTo":"","text":"I’ve thrown some clothes away because of the grease.... I’ll try this trick next time","replyToPid":0}
 楼主| 发表于 2019-10-4 08:18:51 来自手机 | 显示全部楼层
658864 发表于 2019-10-03 23:00:22 I’ve thrown some clothes away because of the grease.... I’ll try this trick next time
","text":"For grease specific I used to haul tanker with old grease and would be covered in it I always used the fast orange grease X detergent in hot water which works great it’s just expensive. Club soda is cheap and works pretty good but it takes multiple soaks and a little elbow grease. Depending on intensity of the grease I used to do both the club soda and the detergent which completely got the grease out but again detergent is kinda expensive. ","replyToPid":220479}
GMT+8, 2026-4-17 23:06 , Processed in 0.076126 second(s), 24 queries .
