查看: 673|回复: 35
mmmm What’s wrong in this photo?
 楼主| 发表于 2019-10-3 21:42:15 来自手机 | 显示全部楼层 |阅读模式
{"text":"","videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":960.0,\"name\":\"\",\"url\":\"\",\"width\":540.0}]","canComment":true}
发表于 2019-10-4 04:41:56 来自手机 | 显示全部楼层
{"replyTo":"","text":"the Driver needs to go back to Load Securement class","replyToPid":0}
回复 支持 6 反对 0
发表于 2019-10-4 05:04:07 来自手机 | 显示全部楼层
{"replyTo":"","text":"This is the count down to extinction!","replyToPid":0}
发表于 2019-10-4 09:55:31 来自手机 | 显示全部楼层
{"replyTo":"","text":"no bungee cords in the front or the back of it not good","replyToPid":0}
发表于 2019-10-4 09:37:38 来自手机 | 显示全部楼层
{"replyTo":"","text":"There isn’t enough coil racks to begin wit .... you’re supposed to use chains and ratchet or over center binders to secure the chains not supposed to use straps to hold down a steel coil .... there is no friction mat this is just all bad ","replyToPid":0}
发表于 2019-10-4 06:51:27 来自手机 | 显示全部楼层
{"replyTo":"","text":"I’m surprised the shipper let him leave like that","replyToPid":0}
发表于 2019-10-5 11:43:44 来自手机 | 显示全部楼层
{"replyTo":"","text":"I don't remember anything about \"chains only\" on coils, only boulders.  I had to check my FMCSR for section 393.120...  nope...  straps are fine as it says \"tiedowns\", not \"chains\" many times.  The driver could use steel banding if they wanted, since its rated.  Steel banding isn't ideal, but it's legal.","replyToPid":0}
发表于 2019-10-4 04:23:55 来自手机 | 显示全部楼层
{"replyTo":"","text":"wow, and yet the D.O.T. put people out of service for a rubbed air line","replyToPid":0}
发表于 2019-10-4 03:31:01 来自手机 | 显示全部楼层
{"replyTo":"","text":"looks good.. send it","replyToPid":0}
发表于 2019-10-9 05:31:34 来自手机 | 显示全部楼层
764851 发表于 2019-10-03 22:36:07 van driver here. guessing the straps are loose but could be wrong. let me know so i know to stay away away from ppl like this on highway
","text":"you never strap a coil.. chains always.. if done right there fine.   but there's a reason the way that coil is loaded,  is called suicide..","replyToPid":220463}
发表于 2019-10-6 21:36:46 来自手机 | 显示全部楼层
{"replyTo":"","text":"i guess! but my straps are allllll very very very very old! ! i use chains all the time cause i trust it more than a old 10 years old cut up worn iut straps; my chains are all very bery very old too","replyToPid":0}
发表于 2019-10-4 04:07:22 来自手机 | 显示全部楼层
{"replyTo":"","text":"Mmm, nothing, the driver probably isn't going to make it to pick up another load and that's a good thing. I hope he/she is the only casualty.","replyToPid":0}
发表于 2019-10-4 04:36:13 来自手机 | 显示全部楼层
{"replyTo":"","text":"I don’t drive a flatbed but to me one of the straps it’s loose and I will chain it up probably. Again I’m not a flatbed driver.","replyToPid":0}
发表于 2019-10-4 06:11:35 来自手机 | 显示全部楼层
{"replyTo":"","text":"brown straps look loose","replyToPid":0}
发表于 2019-10-4 06:12:08 来自手机 | 显示全部楼层
{"replyTo":"","text":"plus they are on wrong","replyToPid":0}
发表于 2019-10-4 06:36:07 来自手机 | 显示全部楼层
{"replyTo":"","text":"van driver here. guessing the straps are loose but could be wrong. let me know so i know to stay away away from ppl like this on highway","replyToPid":0}
GMT+8, 2026-4-20 13:18 , Processed in 0.139529 second(s), 24 queries .
