查看: 154|回复: 4
Good morning fellow steering wheel holders. Is there any adapter that I can get to use these for USB?
 楼主| 发表于 2019-10-3 21:32:27 来自手机 | 显示全部楼层 |阅读模式
{"text":"","videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":853.0,\"name\":\"\",\"url\":\"\",\"width\":640.0}]","canComment":true}
发表于 2019-10-4 02:02:39 来自手机 | 显示全部楼层
{"replyTo":"","text":"It’s not audio. It’s 12v power. And yes, there is an adapter for that, try Amazon. ","replyToPid":0}
发表于 2019-10-3 21:58:43 来自手机 | 显示全部楼层
{"replyTo":"","text":"Wire in a cig lighter. \n\n","replyToPid":0}
发表于 2019-10-3 22:21:41 来自手机 | 显示全部楼层
{"replyTo":"","text":"if it's for audio, and you have a earphone jack in your device, cut the wires at the end where the headphones are at, and use those","replyToPid":0}
发表于 2019-10-4 00:26:09 来自手机 | 显示全部楼层
{"replyTo":"","text":"1. Order a Dual USB Fast Charger Socket Power Outlet \n2. Drill a hole wherever you want a USB outlet. \n3. Install USB outlet \n4. Secure back screw\n5. Wire to the positive and negative sides of your cb power jack \n5* wire and install switch between USB outlet and power source. \nDIY project... \n1 to 2 hours \n** Tools **\n- Phillips flat head screwdriver \n- Small ratchet/ wrench set \n- Drill or similar tool\n- Hole saw the size of the USB outlet case\n(probably 1 5/8ths, any hardware store)\n- Amazon online\nDual USB Fast Charger Socket Power Outlet approximately 10 - 15$ each (get 2)\n\n* Optional *\nElectrical tape\nExtra black and red wire (add wire to increase mounting distance from power source)\nWire butt connectors\nWire ring connectors\nHeat shrink tubing\n=========\nMeasure Measure Measure\n\n-Drop down panel to access the wire behind the CB power jack.\n-Drill hole wherever you want the outlet.\n-attach wires from back of outlet to CB power jack.\n-install USB outlet with supplied nut connector (self explanatory when you see it)\n-plug wires into back of outlet. \nClose up any interior truck panels you opened. \nOptional.... \nMake wires longer if you plan on cleaner/ further from power source installation. \n\nThese work great, and can be installed almost anywhere in your truck.","replyToPid":0}
GMT+8, 2026-4-19 23:28 , Processed in 0.115242 second(s), 24 queries .
