查看: 206|回复: 8
Why I Hate Freighshakers
 楼主| 发表于 2019-10-2 23:31:42 来自手机 | 显示全部楼层 |阅读模式
{"text":"everytime.","videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":1134.0,\"name\":\"\",\"url\":\"\",\"width\":2016.0}]","canComment":true}
发表于 2019-10-3 02:18:28 来自手机 | 显示全部楼层
{"replyTo":"","text":"Clearance light seals easy fix ","replyToPid":0}
发表于 2019-10-3 01:58:06 来自手机 | 显示全部楼层
{"replyTo":"","text":"Freightliners, Internationals, and now KW’s are all crap since they started sharing manufacturing operations with each other 🙄","replyToPid":0}
发表于 2019-10-3 02:02:35 来自手机 | 显示全部楼层
{"replyTo":"","text":"My KW leaks I’ve replaced the seals and water just keeps finding away in. Trucks aren’t built like they used to be. ","replyToPid":0}
发表于 2019-10-3 03:14:32 来自手机 | 显示全部楼层
{"replyTo":"","text":"Poor manufacturing","replyToPid":0}
发表于 2019-10-3 03:29:51 来自手机 | 显示全部楼层
{"replyTo":"","text":"clearance light missing or damaged seals. replace or RTV those things and it's fixed.","replyToPid":0}
发表于 2019-10-3 07:36:18 来自手机 | 显示全部楼层
{"replyTo":"","text":"I Love a Freightliner...get over it🤪✌🏽","replyToPid":0}
发表于 2019-10-3 08:59:56 来自手机 | 显示全部楼层
{"replyTo":"","text":"Mine leaked today as well. Think im going to silicon them. I used to repair Hot Tubs and I used a silicone called GE II. 8 bucks per tube but it worked well. Kept the water in the hot tub so why not use to keep the rain out.","replyToPid":0}
发表于 2019-10-3 13:49:32 来自手机 | 显示全部楼层
{"replyTo":"","text":"frieghtliner is junk all around","replyToPid":0}
GMT+8, 2026-2-12 03:58 , Processed in 0.117859 second(s), 24 queries .
