查看: 130|回复: 9
DOT weigh stations
 楼主| 发表于 2019-10-2 22:31:29 来自手机 | 显示全部楼层 |阅读模式
{"text":"Driving from Sonora,TX - Chorpus Christi, is there any DOT weigh stations open?","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-10-2 23:48:45 来自手机 | 显示全部楼层
435615 发表于 2019-10-02 15:19:47 Should be able to use TP map for that info..
","text":"my thoughts exactly. the little button that says, places. I'm sure that will say if they are all open or closed. seems like everyone just wants everyone else to do there job for them nowadays. 👎","replyToPid":219400}
 楼主| 发表于 2019-10-8 00:17:38 来自手机 | 显示全部楼层
816156 发表于 2019-10-07 16:16:46 Teach a man to fish.......
","text":"👍","replyToPid":222942}
发表于 2019-10-3 11:01:42 来自手机 | 显示全部楼层
{"replyTo":"","text":"Not tonight, they were close. ","replyToPid":0}
发表于 2019-10-3 00:42:36 来自手机 | 显示全部楼层
{"replyTo":"","text":"I37 three rivers TX shows open in the TP map","replyToPid":0}
发表于 2019-10-2 23:19:47 来自手机 | 显示全部楼层
{"replyTo":"","text":"Should be able to use TP map for that info..","replyToPid":0}
发表于 2019-10-3 10:38:05 来自手机 | 显示全部楼层
{"replyTo":"","text":"This very app should tell you neighbor. Just bring up the map.","replyToPid":0}
 楼主| 发表于 2019-10-8 00:10:25 来自手机 | 显示全部楼层
{"replyTo":"","text":"Negative....I'm not sure sssI'm just new to the app, I later found out how to use it. Thanks for the  judgmental comment.","replyToPid":0}
 楼主| 发表于 2019-10-8 00:11:30 来自手机 | 显示全部楼层
{"replyTo":"","text":"Negative....I'm just new to the app, I later found out how to use it. Thanks for the  judgmental comment.","replyToPid":0}
 楼主| 发表于 2019-10-8 00:15:17 来自手机 | 显示全部楼层
196330 发表于 2019-10-03 03:01:42 Not tonight, they were close.
","text":"Thanks to everyone who was helpfu, and not leave a negative comment","replyToPid":219876}
GMT+8, 2026-2-12 09:20 , Processed in 0.180141 second(s), 24 queries .
