查看: 253|回复: 13
Cruise control help
 楼主| 发表于 2019-10-2 09:47:33 来自手机 | 显示全部楼层 |阅读模式
{"text":"My crappy Wabco Adaptive Cruise system is faulted again and it won’t let me set cruise control. The last time this happened, I was somehow able to set regular Cruise despite the Adaptive being unavailable. I have no idea what I did to make that happen, and now I can’t figure out how to do it again. Anyone know? I appreciate any help 😁","videos":"[]","link":"{}","pics":"[]","canComment":true}
 楼主| 发表于 2019-10-30 00:03:30 来自手机 | 显示全部楼层
497499 发表于 2019-10-29 06:08:01 Clean the radar sensor on the front of the truck. Mine acts like that when it gets dirty or icy. I just pull over, clean it off and it works fine again. It looks like a black plastic rectangle or square located somewhere near the bumper or grill.
","text":"I know about all that. So I took it to Kenworth and of course they charged me $300 for a fuse. Didn’t wanna figure out what caused it to go. Just wanted to fix a symptom. Go figure 😖","replyToPid":237350}
发表于 2019-10-29 14:08:01 来自手机 | 显示全部楼层
{"replyTo":"","text":"Clean the radar sensor on the front of the truck. Mine acts like that when it gets dirty or icy. I just pull over, clean it off and it works fine again. It looks like a black plastic rectangle or square located somewhere near the bumper or grill. ","replyToPid":0}
 楼主| 发表于 2019-10-2 21:45:13 来自手机 | 显示全部楼层
{"replyTo":"","text":"2019 KW T680","replyToPid":0}
发表于 2019-10-3 01:37:37 来自手机 | 显示全部楼层
{"replyTo":"","text":"Might try messing with the clutch pedal there’s a switch down there that kicks the cruise off when you tap the pedal might be stuck a little and make sure there is nothing like a rock under the brake pedal ","replyToPid":0}
 楼主| 发表于 2019-10-3 04:16:38 来自手机 | 显示全部楼层
674413 发表于 2019-10-02 17:37:37 Might try messing with the clutch pedal there’s a switch down there that kicks the cruise off when you tap the pedal might be stuck a little and make sure there is nothing like a rock under the brake pedal
","text":"It’s an automatic 😕","replyToPid":219481}
发表于 2019-10-3 04:35:13 来自手机 | 显示全部楼层
{"replyTo":"","text":"Well that changes things ","replyToPid":0}
发表于 2019-10-5 05:26:41 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"Reboot the truck. let the computer cycle before you turn it on"}
 楼主| 发表于 2019-10-5 23:54:29 来自手机 | 显示全部楼层
47495 发表于 2019-10-04 21:26:41 Reboot the truck. let the computer cycle before you turn it on
","text":"I tried that 😕","replyToPid":221104}
发表于 2019-10-30 00:24:22 来自手机 | 显示全部楼层
{"replyToPid":237521,"replyTo":"
599477 发表于 2019-10-29 16:03:30 I know about all that. So I took it to Kenworth and of course they charged me $300 for a fuse. Didn’t wanna figure out what caused it to go. Just wanted to fix a symptom. Go figure 😖
","text":"Ouch. Not under warranty I take it. Ever since KW started sharing assembly lines and parts with Freightliner to save money their electrical issues have increased significantly. Freightliners, KW’s, and Internationals all three have pretty bad reputations for having electrical anomalies. "}
GMT+8, 2026-4-17 00:22 , Processed in 0.110726 second(s), 24 queries .
