查看: 317|回复: 17
any recommendations about gps.Im new driver.whant to make sure which gps to buy.
 楼主| 发表于 2019-10-1 14:24:44 来自手机 | 显示全部楼层 |阅读模式
发表于 2019-10-1 17:01:35 来自手机 | 显示全部楼层
{"replyTo":"","text":"Ive used google maps for 3 years. avoid suspicious roads with google  and check the map. trucker GPS are overrated and a waste of money.","replyToPid":0}
回复 支持 2 反对 3
发表于 2019-10-2 02:45:27 来自手机 | 显示全部楼层
{"replyTo":"","text":"I recommend Rand McNally or Garmin, but if you have a second phone or tablet you can download Co Pilot Truck. DO NOT USE Google Maps!!! It will get you into major trouble. Don’t listen to so called people claiming to be safe and professional truck drivers and are using Google Maps. I’ve seen too many drivers get stuck and even fired for using what looked fine on their phone, but some dimensional aspects of routes you just can’t quantify or visualize on a 2d map, especially when that specific tile is outdated. ","replyToPid":0}
发表于 2019-10-22 07:19:54 来自手机 | 显示全部楼层
{"replyTo":"","text":"you can use Google Maps along with truckers path and you will do just fine","replyToPid":0}
发表于 2019-10-2 10:03:28 来自手机 | 显示全部楼层
{"replyTo":"","text":"Rand Mcnally Trucker Atlas","replyToPid":0}
发表于 2019-10-2 06:19:33 来自手机 | 显示全部楼层
{"replyTo":"","text":"Definitely Rand Mcnally","replyToPid":0}
发表于 2019-10-1 16:34:05 来自手机 | 显示全部楼层
{"replyTo":"","text":"Garmin dezl","replyToPid":0}
发表于 2019-10-1 14:54:47 来自手机 | 显示全部楼层
{"replyTo":"","text":"2020 Atlas","replyToPid":0}
发表于 2019-10-22 11:47:58 来自手机 | 显示全部楼层
{"replyTo":"","text":"I tried Garmin and Rand. I prefer Garmin and Google together . Rand is rubbish lol.","replyToPid":0}
发表于 2019-10-1 21:27:59 来自手机 | 显示全部楼层
{"replyTo":"","text":"i use garmin.remember there all crap.i like being able to find places like walmart burger king cvs and know it will bring me truck route there","replyToPid":0}
发表于 2019-10-22 02:33:46 来自手机 | 显示全部楼层
{"replyTo":"","text":"NONE!! buy a good trucker atlas,  save your money","replyToPid":0}
发表于 2019-10-2 02:47:13 来自手机 | 显示全部楼层
{"replyTo":"","text":"If you have an iPhone you can try TruckMap. It’s free, but it isn’t onboard maps, it’s only streaming so you have to have a cellular data signal to use it. ","replyToPid":0}
发表于 2019-10-2 05:03:56 来自手机 | 显示全部楼层
497499 发表于 2019-10-01 18:45:27 I recommend Rand McNally or Garmin, but if you have a second phone or tablet you can download Co Pilot Truck. DO NOT USE Google Maps!!! It will get you into major trouble. Don’t listen to so called people claiming to be safe and professional truck drivers and are using Google Maps. I’ve seen too many drivers get stuck and even fired for using what looked fine on their phone, but some dimensional aspects of routes you just can’t quantify or visualize on a 2d map, especially when that specific tile is outdated.
","text":"I use google maps along with an atlas and truck gps to see where I’m going also you can use latitude longitude to pinpoint locations so you don’t go down the wrong road. If you know how to you it it’s not bad. Also check local no truck/truck routes. ","replyToPid":218748}
GMT+8, 2026-4-17 23:06 , Processed in 0.112727 second(s), 24 queries .
