查看: 97|回复: 4
Really Uber Freight
 楼主| 发表于 2019-10-1 07:04:40 来自手机 | 显示全部楼层 |阅读模式
{"text":"Uber Freight is stalking me.. 94 times in 3 days is a little excessive!! ","videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":1008.0,\"name\":\"\",\"url\":\"\",\"width\":568.0}]","canComment":true}
发表于 2019-10-1 16:42:16 来自手机 | 显示全部楼层
{"replyTo":"","text":"I can guarantee you 100% that if you have a mobile phone on you you are tracked no matter the settings any user uses. Maybe Uber is not able to track you if you if you turn off the location sharing setting but you ARE tracked just having a phone. \nHell, ALL the trucks with computers track every single thing that is done in the truck, your speed, your latitude and longitude, when you hit the brakes, how fast you were going at any given moment, and logs that information, and I'm not talking about just ELD; the on board computer logs all that information.","replyToPid":0}
发表于 2019-10-1 23:18:03 来自手机 | 显示全部楼层
{"replyTo":"","text":"You read the info. Switch it or don’t ","replyToPid":0}
发表于 2019-10-2 02:39:43 来自手机 | 显示全部楼层
{"replyTo":"","text":"Have you seen success with Uber Freight? How are the rates and variety of freight? ","replyToPid":0}
 楼主| 发表于 2019-10-4 02:19:53 来自手机 | 显示全部楼层
497499 发表于 2019-10-01 18:39:43 Have you seen success with Uber Freight? How are the rates and variety of freight?
","text":"I like it better than DAT and other boards I have tried.. great interface and easy to use","replyToPid":218733}
GMT+8, 2026-2-13 13:03 , Processed in 0.058114 second(s), 23 queries .
