查看: 159|回复: 0
Clutch Linkage
 楼主| 发表于 2019-1-24 18:25:44 来自手机 | 显示全部楼层 |阅读模式
{"text":"I am working on a 2007 W900 Kenworth and going to replace the linkage from the clutch pedal down to the other linkage and replace the ball joints on the other linkage. Just wondering what is the best way to get at them. The reason I am changing them is the clutch pedal wont return to home position, was told that this could be the cause.","pics":"[]","canComment":true}
GMT+8, 2026-3-21 09:30 , Processed in 0.066783 second(s), 23 queries .
