查看: 40|回复: 2
A steam cleaner that will work with 1000w inverters?
 楼主| 发表于 2019-9-29 01:27:47 来自手机 | 显示全部楼层 |阅读模式
{"text":"I was just at Walmart, checking out this little unit\n\nhttps://www.walmart.com/ip/BISSELL-Little-Green-Pro-Portable-Carpet-Cleaner-2505/660022760\n\nBut I could not find wattage info to see if it would work with 1000 watts. Has anyone bought anything like this for inside truck? It would be really cool to have steam cleaned seats and rugs all the time.","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-9-30 02:26:45 来自手机 | 显示全部楼层
{"replyTo":"","text":"https://www.bissell.com/little-green-proheat-portable-carpet-cleaner-2513g#specs\n\nlooks like 3 amps. so at 120vac im thinking that would be 360w... but my math might be wrong.\n\nhttps://www.rapidtables.com/convert/electric/3-amp-to-watt.html.","replyToPid":0}
 楼主| 发表于 2019-10-10 09:40:40 来自手机 | 显示全部楼层
724590 发表于 2019-09-29 18:26:45 https://www.bissell.com/little-green-proheat-portable-carpet-cleaner-2513g#specs\n\nlooks like 3 amps. so at 120vac im thinking that would be 360w... but my math might be wrong.\n\nhttps://www.rapidtables.com/convert/electric/3-amp-to-watt.html.
","text":"Thanks, I couldn’t find that. I’m gonna grab one and get these old seats clean!","replyToPid":217628}
GMT+8, 2026-2-12 12:47 , Processed in 0.070106 second(s), 23 queries .
