查看: 856|回复: 30
HELP AMIGOS
 楼主| 发表于 2019-9-27 13:41:25 来自手机 | 显示全部楼层 |阅读模式
{"text":"I put unleaded in the tank what do I do before the boss finds out ","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-9-28 07:26:47 来自手机 | 显示全部楼层
{"replyTo":"","text":"I'm pretty sure whatever you put in was diesel because you'd have a hell of a time getting your big truck to a gas pump for cars","replyToPid":0}
回复 支持 6 反对 0
发表于 2019-9-27 14:13:08 来自手机 | 显示全部楼层
{"replyTo":"","text":"Nothing, it will be fine.","replyToPid":0}
回复 支持 3 反对 3
发表于 2019-9-28 11:07:50 来自手机 | 显示全部楼层
{"replyTo":"","text":"Put your m0uth on the pipe and $uck it out. ","replyToPid":0}
回复 支持 5 反对 1
 楼主| 发表于 2019-9-28 12:17:34 来自手机 | 显示全部楼层
792495 发表于 2019-09-28 03:07:50 Put your m0uth on the pipe and $uck it out.
","text":"I like to save my $ucking skills for the weekends ","replyToPid":216498}
发表于 2019-9-28 05:20:32 来自手机 | 显示全部楼层
816801 发表于 2019-09-27 12:28:21 Not sure, the pump said suprema dieselina.. maybe it’s a 2020 thing?
","text":"dieselina sounds like female diesel. for female trucks maybe.","replyToPid":216018}
发表于 2019-9-28 09:25:37 来自手机 | 显示全部楼层
{"replyTo":"","text":"Blame it on the slip seater. ","replyToPid":0}
发表于 2019-9-28 05:50:30 来自手机 | 显示全部楼层
688720 发表于 2019-09-27 21:20:32 dieselina sounds like female diesel. for female trucks maybe.
","text":"Automatics 👙","replyToPid":216361}
发表于 2019-9-27 22:19:15 来自手机 | 显示全部楼层
","text":"Oh that sounds like Diesel fuel 😭😭😂😭💀","replyToPid":216018}
发表于 2019-9-28 11:42:06 来自手机 | 显示全部楼层
","text":"😂😂😂😂😂😜😜😜😂😂😂","replyToPid":216498}
发表于 2019-9-28 07:01:19 来自手机 | 显示全部楼层
{"replyTo":"","text":"this makes no sense to me","replyToPid":0}
发表于 2019-9-27 17:38:51 来自手机 | 显示全部楼层
{"replyTo":"","text":"All gas is unleaded in 2019 did you put Gasoline in a Diesel truck ? ","replyToPid":0}
 楼主| 发表于 2019-9-27 20:26:35 来自手机 | 显示全部楼层
817113 发表于 2019-09-27 06:13:08 Nothing, it will be fine.
","text":"Thanks man, about 250 miles out and getting great mpg. Strongly recommend!! ","replyToPid":215870}
 楼主| 发表于 2019-9-27 20:28:21 来自手机 | 显示全部楼层
669593 发表于 2019-09-27 09:38:51 All gas is unleaded in 2019 did you put Gasoline in a Diesel truck ?
","text":"Not sure, the pump said suprema dieselina.. maybe it’s a 2020 thing? ","replyToPid":215946}
发表于 2019-9-28 06:24:29 来自手机 | 显示全部楼层
{"replyTo":"","text":"roll with it and keep your lips shut","replyToPid":0}
GMT+8, 2026-4-17 05:11 , Processed in 0.150926 second(s), 24 queries .
