查看: 480|回复: 24
New Driver
 楼主| 发表于 2019-9-27 09:40:38 来自手机 | 显示全部楼层 |阅读模式
{"text":"I will be hitting the road next week solo driving...Any good advice out there???","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-9-27 14:11:48 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"Well Rudolph, with your nose so bright, don't hit any reindeers when you drive at night."}
回复 支持 8 反对 1
发表于 2019-9-27 13:37:17 来自手机 | 显示全部楼层
{"replyTo":"","text":"dont let other drivers or people intimidate you when your backing into a spot. if it takes you 30 minutes then it takes you 30 minute. better safe than sorry. Goodluck out here mate ","replyToPid":0}
回复 支持 9 反对 0
发表于 2019-9-27 13:46:37 来自手机 | 显示全部楼层
{"replyTo":"","text":"Baby Wipes. ","replyToPid":0}
回复 支持 7 反对 0
发表于 2019-9-30 05:56:30 来自手机 | 显示全部楼层
{"replyTo":"","text":"Dont talk to trannys or plp who drive Volvos. And never talk to trannys who drive Volvos!","replyToPid":0}
回复 支持 7 反对 0
发表于 2019-9-27 13:25:41 来自手机 | 显示全部楼层
{"replyTo":"","text":"Always scan ahead. And when backing use the Goal system \nGet\nOut\nAnd\nLook. \nTrust your gut don’t second guess anything if it doesn’t feel right then think before you put yourself in a bad situation. ","replyToPid":0}
回复 支持 6 反对 0
发表于 2019-9-27 09:55:26 来自手机 | 显示全部楼层
{"replyTo":"","text":"Get good sleep young grasshopper ✊🏽","replyToPid":0}
发表于 2019-10-4 07:02:45 来自手机 | 显示全部楼层
703174 发表于 2019-10-02 08:13:41 Don’t listen to other drivers
","text":"😂😂😂😂 so... ignore everything that’s been said here? ","replyToPid":219272}
发表于 2019-9-27 18:00:48 来自手机 | 显示全部楼层
{"replyTo":"","text":"always remember no matter how intimidating and aggravating and frustrating and maddening it seems now, it will all come together in about 6 months, where you will still be experiencing all of the above mentioned emotions, but you'll be doing it without even thinking about it anymore😉","replyToPid":0}
发表于 2019-9-30 09:23:03 来自手机 | 显示全部楼层
{"replyTo":"","text":"If you can't see it, don't trust it. If it doesn't feel right, look right, or if you're not comfortable with it, don't do it. 25% of driving a truck in snow is skill. The other 75% is knowing when not to do it. And as someone else once said, \"You can go too slow as much as you want, you can only go too fast once.\"","replyToPid":0}
发表于 2019-9-28 05:43:13 来自手机 | 显示全部楼层
{"replyTo":"","text":"Scan the entire area around your truck every few seconds whilst moving, especially in heavy traffic. Good luck newby.","replyToPid":0}
发表于 2019-9-28 13:06:08 来自手机 | 显示全部楼层
{"replyTo":"","text":"don't get a governed truck!","replyToPid":0}
 楼主| 发表于 2019-9-29 00:12:04 来自手机 | 显示全部楼层
{"replyTo":"","text":"Lol😂","replyToPid":215866}
GMT+8, 2026-4-17 19:44 , Processed in 0.130529 second(s), 24 queries .
