查看: 335|回复: 11
Trucks stuck under bridges compilation
 楼主| 发表于 2019-9-27 01:45:05 来自手机 | 显示全部楼层 |阅读模式
{"text":"( response to the other topic with the Swift truck “stuck” under 12’2” bridge)","videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":1408.0,\"name\":\"\",\"url\":\"\",\"width\":1877.0},{\"description\":\"\",\"height\":1408.0,\"name\":\"\",\"url\":\"\",\"width\":1877.0},{\"description\":\"\",\"height\":1408.0,\"name\":\"\",\"url\":\"\",\"width\":1877.0},{\"description\":\"\",\"height\":1408.0,\"name\":\"\",\"url\":\"\",\"width\":1877.0}]","canComment":true}
 楼主| 发表于 2019-9-27 06:32:07 来自手机 | 显示全部楼层
764851 发表于 2019-09-26 21:36:13 right. i was just asking cause i see so many and its like why would you even try if the sign says anything less.
","text":"There’s the case of the state New York, where I was told the measuring starts from the axle so you’ll have a 13’6” truck fit under a bridge with a lower height displayed... so that’s a bit confusing, because the for the rest of the country what the sign says is the actual height...","replyToPid":215664}
发表于 2019-9-27 04:31:52 来自手机 | 显示全部楼层
{"replyTo":"","text":"are all dry vans not 13.6??","replyToPid":0}
 楼主| 发表于 2019-9-27 04:57:53 来自手机 | 显示全部楼层
764851 发表于 2019-09-26 20:31:52 are all dry vans not 13.6??
","text":"Yes they are, and in the other post a 13’6” made it under the 12’2” bridge. My point is, here’s how a truck that hits a 12’2” bridge ends up like....","replyToPid":215627}
发表于 2019-9-27 05:02:53 来自手机 | 显示全部楼层
","text":"Hell I thought all when had breast but her come you looking like a man. My point is things aren’t always what they seem ","replyToPid":215627}
发表于 2019-9-27 05:31:49 来自手机 | 显示全部楼层
{"replyTo":"","text":"The ladder amuses me 😆","replyToPid":0}
发表于 2019-9-27 05:36:13 来自手机 | 显示全部楼层
658864 发表于 2019-09-26 20:57:53 Yes they are, and in the other post a 13’6” made it under the 12’2” bridge. My point is, here’s how a truck that hits a 12’2” bridge ends up like....
","text":"right. i was just asking cause i see so many and its like why would you even try if the sign says anything less.","replyToPid":215640}
发表于 2019-9-27 07:28:35 来自手机 | 显示全部楼层
{"replyTo":"","text":"I’m glad to walk away Swift long time ago, thanks lord ","replyToPid":0}
发表于 2019-9-27 07:29:38 来自手机 | 显示全部楼层
{"replyTo":"","text":"They call themselves Professional Driver?","replyToPid":0}
发表于 2019-9-27 21:42:33 来自手机 | 显示全部楼层
658864 发表于 2019-09-26 22:32:07 There’s the case of the state New York, where I was told the measuring starts from the axle so you’ll have a 13’6” truck fit under a bridge with a lower height displayed... so that’s a bit confusing, because the for the rest of the country what the sign says is the actual height...
","text":"yup, Queens and Brooklyn","replyToPid":215683}
GMT+8, 2026-4-19 15:49 , Processed in 0.061588 second(s), 24 queries .
