查看: 118|回复: 9
I don't understand why fellow trucker do this. I just swallow my pride and slow down.
 楼主| 发表于 2019-9-27 00:57:18 来自手机 | 显示全部楼层 |阅读模式
{"text":"Let em pass even tho you won't get there faster.\n","videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":628.0,\"name\":\"\",\"url\":\"\",\"width\":538.0}]","canComment":true}
发表于 2019-9-27 01:36:56 来自手机 | 显示全部楼层
{"replyTo":"","text":"or sometimes it's a 55 and a half and  a 45. then when the 55 and a half goes to pass, the 45 says oh crap someone is passing me so I should pick it up to just enough speed that they cannot get back into the right lane...","replyToPid":0}
发表于 2019-9-27 04:16:48 来自手机 | 显示全部楼层
{"replyTo":"","text":"all governed trucks should have the passmart from the freightliner. when you're passing you can double tap the accelerator and you can override the governor and speed up freely. its limited to 30 minutes of  passmart for 24hr period","replyToPid":0}
发表于 2019-9-27 03:58:37 来自手机 | 显示全部楼层
716846 发表于 2019-09-26 17:36:56 or sometimes it's a 55 and a half and  a 45. then when the 55 and a half goes to pass, the 45 says oh crap someone is passing me so I should pick it up to just enough speed that they cannot get back into the right lane...
","text":"It’s true. \n\nPeople are dîcks","replyToPid":215511}
发表于 2019-9-27 04:29:41 来自手机 | 显示全部楼层
{"replyTo":"","text":"Agreed.  If I see another driver trying to creep past me I just slow down a mile or so and let them on by.  ","replyToPid":0}
发表于 2019-9-27 12:37:36 来自手机 | 显示全部楼层
731713 发表于 2019-09-26 20:16:48 all governed trucks should have the passmart from the freightliner. when you're passing you can double tap the accelerator and you can override the governor and speed up freely. its limited to 30 minutes of  passmart for 24hr period
","text":"Smart companies would do this because there's nothing more dangerous than a motorist losing their cool because of idiocy surrounding them.\nI suffered 75-100 miles stuck behind a May Trucking company driver today because everytime I had a chance to pass, one of the two lanes going east in Wyoming would shut down for construction and being unsure about my ability to pass him expediently I just shut it down.\nWhen I see another driver in the same predicament I'll generally hold back at the top and let them on bye,  but those days I fear are coming to a close. Tired of screwing myself by being the nice guy.","replyToPid":215614}
发表于 2019-9-27 06:24:28 来自手机 | 显示全部楼层
{"replyTo":"","text":"all they  have to do is when they are going only 1 mph faster is slow down and  Follow the driver. They don't need to pass. does it really makes a difference? I do it all the time .","replyToPid":0}
发表于 2019-9-27 07:13:05 来自手机 | 显示全部楼层
{"replyTo":"","text":"I call it \"Handicap racing\"!","replyToPid":0}
发表于 2019-9-27 22:00:46 来自手机 | 显示全部楼层
649838 发表于 2019-09-26 20:29:41 Agreed.  If I see another driver trying to creep past me I just slow down a mile or so and let them on by.
","text":"You are a rarity out here, I do the same.","replyToPid":215621}
发表于 2019-9-27 22:22:13 来自手机 | 显示全部楼层
{"replyTo":"","text":"there's easily enough room to slide around on left side at 85 😁","replyToPid":0}
GMT+8, 2026-2-7 14:13 , Processed in 0.065543 second(s), 24 queries .
