查看: 217|回复: 5
Reefer Myth
 楼主| 发表于 2019-5-23 00:55:13 来自手机 | 显示全部楼层 |阅读模式
{"text":"My colleague, who has been a reefer driver for almost all of his 34 years in trucking, perpetuates this sort of \"myth\" that reefer trucks always stick together on truck stop lots, and that dry vans, tankers, flatbeds, and everybody else hates Reefers and tries to stay away from them. Is this really true? ","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-5-23 06:34:45 来自手机 | 显示全部楼层
366847 发表于 2019-05-22 19:20:10 Don’t like our noisy Refridgerated trailers? Stop buying food and medicine. Problem solved. \nTasty stuff. \nReefer drivers bring it.
","text":"It’s not the noise really. it’s more of when it’s irregular noise and not a constant sound that’s annoying. Same thing when trucks idle. ","replyToPid":41106}
发表于 2019-5-23 03:20:10 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"Don’t like our noisy Refridgerated trailers? Stop buying food and medicine. Problem solved. \nTasty stuff. \nReefer drivers bring it. "}
发表于 2019-5-23 01:42:28 来自手机 | 显示全部楼层
{"replyTo":"","text":"We park wherever there’s a spot.  But it IS more or less true that drivers of other types are frequently.... less than happy with our presence.  Especially if the reefer you are pulling is noisy as hell. \nI will say, if I’ve an abnormally noisy reefer, I’ll typically nose into a parking spot instead of backing in","replyToPid":0}
发表于 2019-5-23 01:51:44 来自手机 | 显示全部楼层
157862 发表于 2019-05-22 17:42:28 We park wherever there’s a spot.  But it IS more or less true that drivers of other types are frequently.... less than happy with our presence.  Especially if the reefer you are pulling is noisy as hell. \nI will say, if I’ve an abnormally noisy reefer, I’ll typically nose into a parking spot instead of backing in
","text":"Nailed it","replyToPid":40945}
发表于 2019-5-23 06:43:46 来自手机 | 显示全部楼层
{"replyTo":"","text":"That is right. Always have courtesy. Reefers are noise.","replyToPid":0}
GMT+8, 2026-3-21 17:30 , Processed in 0.062807 second(s), 24 queries .
