查看: 140|回复: 3
Pulling Dry Vans.
 楼主| 发表于 2019-9-26 04:53:34 来自手机 | 显示全部楼层 |阅读模式
{"text":"I’ve been driving for almost 2 years. All open deck stuff like flats steps and oversize loads. Boss asked if I wanted to pull dry vans right out of where the terminal is located directly to my home city since I asked to be home more often. Was wondering are there any tips to pulling vans? Just being a truck driver you pick up on things like I’ve heard people talking about shortening your 5th wheel for better fuel mileage and what to do when tandems won’t slide or how much weight per hole. Or sliding the tandems to get into a dock easier and things like that. Any tips?","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-9-26 05:45:16 来自手机 | 显示全部楼层
770536 发表于 2019-09-25 21:44:43 sliding you're kidding I'm just roughly 4 to 500 lbs per hole backward if you need to move the weight forward with the tandems forward towards the truck if you need to push the weight back. if you pull the switches your taters won't slide you have two choices rock it backward and forward to get the pennies to unlock or just release the brakes drive around for a bit and then do it again depends don't slide because it didn't have Aaron getting released from the chamber
","text":"sorry for the misspells I use voice text doesn't always get it right","replyToPid":215038}
发表于 2019-9-26 05:44:43 来自手机 | 显示全部楼层
{"replyTo":"","text":"sliding you're kidding I'm just roughly 4 to 500 lbs per hole backward if you need to move the weight forward with the tandems forward towards the truck if you need to push the weight back. if you pull the switches your taters won't slide you have two choices rock it backward and forward to get the pennies to unlock or just release the brakes drive around for a bit and then do it again depends don't slide because it didn't have Aaron getting released from the chamber","replyToPid":0}
 楼主| 发表于 2019-9-26 07:59:38 来自手机 | 显示全部楼层
770536 发表于 2019-09-25 21:45:16 sorry for the misspells I use voice text doesn't always get it right
","text":"Lol it’s ok thanks for some tips. ","replyToPid":215039}
GMT+8, 2026-2-11 19:04 , Processed in 0.059972 second(s), 24 queries .
