查看: 199|回复: 12
windows keep fogging up in rainy weather
 楼主| 发表于 2019-9-26 03:04:15 来自手机 | 显示全部楼层 |阅读模式
{"text":"why does my windows constantly stay foggy when it's raining outside. tried all the heating settings but still stays foggy. need to crank the windows all the way down for it to be gone completely then it just fogs back up. it's a 2020 Volvo vnl 860","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-9-26 04:17:34 来自手机 | 显示全部楼层
{"replyTo":"","text":"Rain-X anti fog solution, comes in a little black and yellow bottle, Walmart or auto parts stores... it works really well... I use it on my glasses and motorcycle face shield too👍🏼","replyToPid":0}
发表于 2019-9-26 04:39:24 来自手机 | 显示全部楼层
{"replyTo":"","text":"if this is happening in the summer. it really is just too much moisture inside the cab. run your ac on defrost until the windshield reaches a temperature level to prevent condensation. this could take some time. usually indicates a leak around the windshield. it doesn't take much to cause the problem. but the ac will dry the air in your cab. each truck has its own idiosyncrasies. try that and give it time. it will clear up. good luck","replyToPid":0}
发表于 2019-9-26 14:44:13 来自手机 | 显示全部楼层
{"replyTo":"","text":"It sounds like there’s a leak somewhere, either in the windshield itself or the HVAC system. Take it to a dealer or shop. In the meantime keep a towel on the dash so you can wipe the windshield in a pinch, and crack the windows temporarily to help dry out the cab. ","replyToPid":0}
发表于 2019-9-27 04:56:05 来自手机 | 显示全部楼层
646385 发表于 2019-09-26 01:46:14 it's as clean as it gets. just bought the truck last week and I dont smoke Haha
","text":"All jokes aside the windows keep fogging up cause you one hot sexy son of (boy watch your mouth) 😂😂😂😂😂😂","replyToPid":215102}
发表于 2019-9-26 03:40:46 来自手机 | 显示全部楼层
646385 发表于 2019-09-25 19:39:21 Already tried that. Helps very minimal unfortunately
","text":"Ya takes awhile for it to do anything. Has to be on full blast very annoying. ","replyToPid":214904}
发表于 2019-9-26 08:04:48 来自手机 | 显示全部楼层
{"replyTo":"","text":"Clean your windows and put the smokes down ","replyToPid":0}
发表于 2019-9-26 09:09:47 来自手机 | 显示全部楼层
{"replyTo":"","text":"I had the same problem in a car.  Turned out the heater core was leaking.","replyToPid":0}
发表于 2019-9-26 09:50:33 来自手机 | 显示全部楼层
{"replyTo":"","text":"my dad used to put his atlas and notebook Kleenex etccc . the defrost didn't seems to work since all the crap was blocking the vents","replyToPid":0}
 楼主| 发表于 2019-9-26 09:46:14 来自手机 | 显示全部楼层
792495 发表于 2019-09-26 00:04:48 Clean your windows and put the smokes down
","text":"it's as clean as it gets. just bought the truck last week and I dont smoke Haha","replyToPid":215061}
发表于 2019-9-26 03:54:04 来自手机 | 显示全部楼层
{"replyTo":"","text":"😂 I'm going to need the vin number? to be able to give you accurate information as to how this problem can be resolved","replyToPid":0}
发表于 2019-9-26 03:36:34 来自手机 | 显示全部楼层
{"replyTo":"","text":"You need to put defrost on. It’s the warm air inside the truck vs the cold outside. ","replyToPid":0}
 楼主| 发表于 2019-9-26 03:39:21 来自手机 | 显示全部楼层
542330 发表于 2019-09-25 19:36:34 You need to put defrost on. It’s the warm air inside the truck vs the cold outside.
","text":"Already tried that. Helps very minimal unfortunately","replyToPid":214902}
GMT+8, 2026-2-13 00:32 , Processed in 0.103193 second(s), 24 queries .
