查看: 276|回复: 20
Good job
 楼主| 发表于 2019-9-26 02:08:38 来自手机 | 显示全部楼层 |阅读模式
{"text":"He delivered that bridge perfectly  ","videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":824.0,\"name\":\"169941/1_1569434915_1569434916.jpg\",\"url\":\"\",\"width\":720.0}]","canComment":true}
发表于 2019-9-26 23:16:57 来自手机 | 显示全部楼层
{"replyTo":"","text":"They are swift. Almost as smart as Climate Change Girl.","replyToPid":0}
发表于 2019-9-26 22:51:34 来自手机 | 显示全部楼层
{"replyTo":"","text":"his trainer said he would make it","replyToPid":0}
发表于 2019-9-26 19:00:22 来自手机 | 显示全部楼层
{"replyTo":"","text":"Maybe you should just read what it says you won’t fit so don’t try","replyToPid":0}
发表于 2019-9-27 01:27:59 来自手机 | 显示全部楼层
{"replyTo":"","text":"It clearly says 12 2! Why would you even try that?! ","replyToPid":0}
 楼主| 发表于 2019-10-2 03:04:07 来自手机 | 显示全部楼层
{"replyTo":"","text":"🤔","replyToPid":214857}
发表于 2019-9-26 18:22:18 来自手机 | 显示全部楼层
{"replyTo":"","text":"it curb height measured from the top of the curb but can't that driver read don't he know the height of his truck🤔","replyToPid":0}
发表于 2019-9-26 02:26:11 来自手机 | 显示全部楼层
{"replyTo":"","text":"the sign is wrong","replyToPid":0}
发表于 2019-9-26 03:48:45 来自手机 | 显示全部楼层
{"replyTo":"","text":"If it’s it New York, I think that’s no mistake.... don’t they start the measuring from the axles, or something like that?","replyToPid":0}
发表于 2019-9-27 01:26:20 来自手机 | 显示全部楼层
295387 发表于 2019-09-26 11:00:22 Maybe you should just read what it says you won’t fit so don’t try
","text":"exactly","replyToPid":215306}
发表于 2019-9-27 01:34:01 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"The height of the truck is 13’6” and that bridge is 12’2”, more than a foot difference and there’s no damage to the truck.... or none that I can see"}
GMT+8, 2026-4-19 16:08 , Processed in 0.126226 second(s), 24 queries .
