请选择 进入手机版 | 继续访问电脑版
查看: 683|回复: 19
30 min break voilation
 楼主| 发表于 2019-9-26 00:35:45 来自手机 | 显示全部楼层 |阅读模式
{"text":"hey guys,\n\nso just screwed up and drove 8hours 17 seconds straight. i thought i could make it but didn't.  \n\nnow my eld showing voilation and i was wondering if there is a way to fix it? keeptruckin eld is the one we use. \n\nand if scale stops me will they fine me? its only 17 seconds but i dont know how dot officer will see it.\n\n","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-9-26 06:23:56 来自手机 | 显示全部楼层
{"replyTo":"","text":"You can edit the time on your on duty time for your pretrip...just change the start time to 20 seconds later.  If you don’t have that option, make a note saying that traffic was backed up on the off ramp or no safe place to pull over...something like that ","replyToPid":0}
发表于 2019-9-26 00:52:33 来自手机 | 显示全部楼层
{"replyTo":"","text":"Kinda up to the cop really. \n\nStraight up it is a violation but 17 seconds. Takes longer to take a pisś","replyToPid":0}
发表于 2019-9-26 01:34:18 来自手机 | 显示全部楼层
{"replyTo":"","text":"You’ll only get fined if DOT pulls your logs for an audit, which is unlikely if your safety rating is good and don’t have multiple log violations piling up. There’s a system in place that flags logs with more violations to be more likely to be audited. It’s just one violation, you should be ok. ","replyToPid":0}
发表于 2019-9-26 08:30:29 来自手机 | 显示全部楼层
{"replyTo":"","text":"You criminal you.. safety hazard to society. 😉","replyToPid":0}
发表于 2019-9-26 08:57:34 来自手机 | 显示全部楼层
{"replyTo":"","text":"Annotate!\n\nLike was said earlier, make a note explaining why you were over. Construction? Traffic jam? Etc etc.\n\nNotes are your friend.","replyToPid":0}
发表于 2019-9-26 09:58:46 来自手机 | 显示全部楼层
{"replyTo":"","text":"just noted like traffic jam. usually dot look back 7 days of logs. you need to plan better. I plan my route the night before.","replyToPid":0}
发表于 2019-9-27 01:13:39 来自手机 | 显示全部楼层
{"replyTo":"","text":"if you get pulled for an inspection, just be nice and pleasant with the officer and he'd likely ignore it.  Officer would have to be really picky to ticket you for that and it would be easy to fight.  I mean, that 17 seconds could have just been getting parked in a truckstop.","replyToPid":0}
发表于 2019-9-26 01:04:15 来自手机 | 显示全部楼层
{"replyTo":"","text":"lol you obviously dont know you're job .","replyToPid":0}
发表于 2019-9-26 01:05:27 来自手机 | 显示全部楼层
{"replyTo":"","text":"no way to fix it legally. maybe your logs department might but not likely. worth a call I would think","replyToPid":0}
 楼主| 发表于 2019-9-26 01:08:59 来自手机 | 显示全部楼层
{"replyTo":"","text":"if they don't notice i won't get fine? i hope its not automatically sent to DOT","replyToPid":0}
发表于 2019-9-26 01:36:29 来自手机 | 显示全部楼层
497499 发表于 2019-09-25 17:34:18 You’ll only get fined if DOT pulls your logs for an audit, which is unlikely if your safety rating is good and don’t have multiple log violations piling up. There’s a system in place that flags logs with more violations to be more likely to be audited. It’s just one violation, you should be ok.
","text":"And, no your company’s log department can’t edit driving time. Only Off Duty not driving, Sleeper Berth, and On Duty not driving. Driving and Personal Conveyance driving cannot be edited. ","replyToPid":214829}
 楼主| 发表于 2019-9-26 01:37:39 来自手机 | 显示全部楼层
{"replyTo":"","text":"thanks guys for answers.","replyToPid":0}
发表于 2019-9-26 02:46:18 来自手机 | 显示全部楼层
659906 发表于 2019-09-25 17:37:39 thanks guys for answers.
","text":"all d.o.t. has to do is plug in there portable computer at stop or scale, and they can pull up everything.","replyToPid":214832}
发表于 2019-9-26 03:50:04 来自手机 | 显示全部楼层
{"replyTo":"","text":"edit a minute off of any on duty time you took, if it's all driving then you have to wait until the next day for it to clear","replyToPid":0}
GMT+8, 2026-4-14 11:21 , Processed in 0.666556 second(s), 24 queries .
