查看: 116|回复: 4
I refuse to pay for a service that WILL NOT locate a place I need to go. I have tried on numerous occasions
 楼主| 发表于 2019-9-25 20:10:28 来自手机 | 显示全部楼层 |阅读模式
发表于 2019-9-26 00:37:04 来自手机 | 显示全部楼层
{"replyTo":"","text":"Hi there,\n\nThank you for reaching to out us. Are you referring to the routing option of the app or are you referring to a place that isn't added yet?\n\nIf you are in need of immediate assistance, you can contact our 24/7 Customer Care hotline at 757-941-7806.\n\nHaul proud. Haul safe.","replyToPid":0}
 楼主| 发表于 2019-9-26 01:00:30 来自手机 | 显示全部楼层
615914 发表于 2019-09-25 16:37:04 Hi there,\n\nThank you for reaching to out us. Are you referring to the routing option of the app or are you referring to a place that isn't added yet?\n\nIf you are in need of immediate assistance, you can contact our 24/7 Customer Care hotline at 757-941-7806.\n\nHaul proud. Haul safe.
","text":"The routing of places I need to go to","replyToPid":214787}
发表于 2019-9-26 03:30:45 来自手机 | 显示全部楼层
{"replyTo":"","text":"Thank you for the clarification. We would like to ensure that you have our latest version. To be able to check this, kindly follow the steps below:\r\n1. Open your Trucker Path App\r\n2. On the lower right corner of your screen kindly click on the “Me” icon\r\n3. Then click on “About”\r\n4. The latest version is Version: 3.6.8 - If this is not the version you have, kindly update your Trucker Path App\r\n\r\nIf you do have the latest version, we will be reporting this to our developers to make sure that this is not an issue with the latest version of the app. As a workaround, we suggest going back to the older version of the app.\r\n\r\nTo do this:\r\n\r\n1. Tap on \"Me\" at the lower right portion of the app.\r\n2. Tap on \"Experience the New Trip Planner\"\r\n3. Tap on \"Go Back to Old Trip Planner\"\r\n\r\nWe appreciate your support.\r\n\r\nHaul Safe. Haul Proud.","replyToPid":0}
 楼主| 发表于 2019-9-26 16:21:02 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"after I updated this to the newer version it is worse. Once I put in my info for my trip plan,  the app completely closes out and shuts down. So far I am EXTREMELY disappointed with your product. when I hear back from you and it still doesn't work that will be strike 3 and I will be finished with it"}
GMT+8, 2026-4-18 20:17 , Processed in 3.135427 second(s), 23 queries .
