查看: 77|回复: 1
PC question
 楼主| 发表于 2019-9-25 02:51:57 来自手机 | 显示全部楼层 |阅读模式
{"text":"I use pc once in a while, and am confident that I'm ok, but this time I'm not positive. So normally I don't get loads back to my terminal city. I usually have to deliver elsewhere and catch a short I had 5 minutes left on my drive clock, and was less than a hour away. I live 2 miles from the yard and I really value home time. I was fixing to take 3 days off. Is that a violation?  ","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-9-25 05:48:18 来自手机 | 显示全部楼层
{"replyTo":"","text":"Only if you have a load it is. The reason is you are advancing the load to the yard for another driver to take. \n\nNow if you were empty that would be fine. ","replyToPid":0}
GMT+8, 2026-4-18 04:28 , Processed in 0.079831 second(s), 23 queries .
