查看: 135|回复: 9
Is it true that smoking cigs can help you stay awake longer?
 楼主| 发表于 2019-9-25 02:48:34 来自手机 | 显示全部楼层 |阅读模式
{"text":"Anyone who smokes cigarettes?  ","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-9-25 05:50:10 来自手机 | 显示全部楼层
{"replyTo":"","text":"Yes it’s true. It gives you something to do. \n\nWhat works really good is stopping and get out of the truck walk around while having a smoke. Works like a timer. ","replyToPid":0}
发表于 2019-9-25 05:58:18 来自手机 | 显示全部楼层
{"replyTo":"","text":"I smoke cigars and it does help me stay awake but at the end of the day what helps me stay awake is anything that engages my mind and takes out the hypnotizing low of the road when I'm a little bit tired","replyToPid":0}
发表于 2019-9-25 15:52:00 来自手机 | 显示全部楼层
{"replyTo":"","text":"A one on one with some powdered cocaine or a hit of crack rock works better then cigarettes ","replyToPid":0}
发表于 2019-9-25 18:39:58 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"Sorry I am going to have to disagree with everyone. No, it does not keep you awake longer. it actually has a reverse effect of that. it will put you to sleep quicker and longer. like forever. as in, six feet under with throat cancer."}
发表于 2019-9-25 07:14:53 来自手机 | 显示全部楼层
{"replyTo":"","text":"yes it does. used it when I was in college and working 2 jobs.","replyToPid":0}
发表于 2019-9-25 07:16:16 来自手机 | 显示全部楼层
{"replyTo":"","text":"Adderall works too.","replyToPid":0}
发表于 2019-9-25 12:43:57 来自手机 | 显示全部楼层
{"replyTo":"","text":"I vape and yes it helps but won’t recommend you to either smoke or vape to stay awake because it is not good for health and is also a waste of money ","replyToPid":0}
发表于 2019-9-25 13:02:28 来自手机 | 显示全部楼层
{"replyTo":"","text":"I wouldn't start smoking because of it, but yes it occupies your face hands and mind so it keeps you more alert for longer. if you are considering starting to smoke for this reason, you're better off just sleeping earlier","replyToPid":0}
发表于 2019-9-25 22:41:00 来自手机 | 显示全部楼层
{"replyTo":"","text":"I used to smoke but that reduces the amount of oxygen you can take in.   That in turns wears you down.  ","replyToPid":0}
GMT+8, 2026-4-19 03:27 , Processed in 0.101071 second(s), 24 queries .
