查看: 158|回复: 12
What is your cure for insomia?
 楼主| 发表于 2019-9-25 02:29:20 来自手机 | 显示全部楼层 |阅读模式
{"text":"Aside from pills  ","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-9-25 14:46:35 来自手机 | 显示全部楼层
{"replyTo":"","text":"two quick beers.","replyToPid":0}
发表于 2019-9-25 15:41:21 来自手机 | 显示全部楼层
{"replyTo":"","text":"Put the phone down ","replyToPid":0}
发表于 2019-9-25 14:02:36 来自手机 | 显示全部楼层
{"replyTo":"","text":"It didn’t work... I’ll try again","replyToPid":214351}
发表于 2019-9-25 04:47:39 来自手机 | 显示全部楼层
{"replyTo":"","text":"Tug it","replyToPid":0}
发表于 2019-9-25 15:41:04 来自手机 | 显示全部楼层
{"replyTo":"","text":"magnesium  from plant source (organic)","replyToPid":0}
发表于 2019-9-25 16:23:27 来自手机 | 显示全部楼层
{"replyTo":"","text":"HA!","replyToPid":214599}
发表于 2019-9-25 17:52:51 来自手机 | 显示全部楼层
{"replyTo":"","text":"try going for a 15 or 20 minute run 35-40 minute walk exercise usually helps get you relaxed or just smoke a joint","replyToPid":0}
发表于 2019-9-25 19:45:28 来自手机 | 显示全部楼层
{"replyTo":"","text":"less stress. find out what's on your mind and fix it","replyToPid":0}
发表于 2019-9-26 00:09:11 来自手机 | 显示全部楼层
{"replyTo":"","text":"quieting my mind through deep breathing using  \"in through nose, out through mouth\" technique.","replyToPid":0}
GMT+8, 2026-4-19 03:37 , Processed in 0.083007 second(s), 24 queries .
