查看: 161|回复: 9
Is the truck routing that comes with the gold membership worth it?
 楼主| 发表于 2019-9-24 13:51:06 来自手机 | 显示全部楼层 |阅读模式
{"text":"Dont have a Garmin/Rand McNally yet so I’m wonderin if this app is a good alternative until I get one","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-9-25 00:44:44 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"In my opinion, Garmin Dezl is great for anything you'll need to do. Never let us down, sometimes it says \"no trucks allowed\" but its lying"}
发表于 2019-9-24 16:30:00 来自手机 | 显示全部楼层
612134 发表于 2019-09-24 06:05:08 I'm on a thirty day free trial right now. I'm not a fan. I would not and will not be paying fo this. so, no. however you are getting it done now without a gps, yourebetter off just sticking with that.
","text":"you can download the app called Road Hunter it's perfect for trucks it shows low bridges it shows truck stops weigh stations pretty much everything you're going to need for trucks and then just compare that map with Google Maps until you get your truck GPS","replyToPid":213982}
发表于 2019-9-24 14:05:08 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"I'm on a thirty day free trial right now. I'm not a fan. I would not and will not be paying fo this. so, no. however you are getting it done now without a gps, yourebetter off just sticking with that."}
发表于 2021-7-27 00:25:53 来自手机 | 显示全部楼层
{"replyTo":"","text":"I've tried TruckMap and Roadhunter side-by-side with my Garmin.\nI was determined to just follow and see....but they routed my to small 2-lane roads..when I could actually see the 4-lane out my window.\nI stuck with it until they stated routing me down county/city roads posted with weight limits of 12k or less.\nGarmin almost always gets me there.  \nWhen Garmin says no truck, use Google maps street view to read the posted signs.   most of the time the part of the road that is posted no trucks is a portion that I'm not planning on traveling to ...like after the end of local Indus park going into residential areas.","replyToPid":0}
发表于 2019-9-25 04:10:07 来自手机 | 显示全部楼层
770536 发表于 2019-09-24 08:30:00 you can download the app called Road Hunter it's perfect for trucks it shows low bridges it shows truck stops weigh stations pretty much everything you're going to need for trucks and then just compare that map with Google Maps until you get your truck GPS
","text":"Thanks, I just downloaded.","replyToPid":213987}
发表于 2019-9-24 20:01:03 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"."}
发表于 2019-9-24 20:01:46 来自手机 | 显示全部楼层
{"replyTo":"","text":"wrong guy, guy. I got my sh!t all in order. I was offered this free gold one month membership. so I figured I would give it a look. since it was free. But I already have my system down. I think you meant to tell that to OTR52 But thanks anyways.","replyToPid":0}
发表于 2019-9-24 22:15:32 来自手机 | 显示全部楼层
{"replyTo":"","text":"Not at all ","replyToPid":0}
发表于 2019-9-25 10:20:52 来自手机 | 显示全部楼层
{"replyTo":"","text":"Yup it sure is the best of the best scouts honor ","replyToPid":0}
GMT+8, 2026-4-19 11:54 , Processed in 0.109365 second(s), 24 queries .
