查看: 300|回复: 18
When you see it
 楼主| 发表于 2019-9-24 02:51:32 来自手机 | 显示全部楼层 |阅读模式
{"text":"Is it a good move or not?  ","videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":960.0,\"name\":\"169941/2_1569264690_1569264690.jpg\",\"url\":\"\",\"width\":720.0}]","canComment":true}
 楼主| 发表于 2019-10-2 02:52:46 来自手机 | 显示全部楼层
817113 发表于 2019-09-24 23:20:22 As long as there us some sort of brake so it doesn't work itself down but I like the idea.  I've pulled many custom trailers that had pneumatic landing gears that were independent of each other for leveling.
","text":"Innovative, right?","replyToPid":214418}
 楼主| 发表于 2019-10-2 02:51:29 来自手机 | 显示全部楼层
612134 发表于 2019-09-24 12:39:49 probably not. no leverage.
","text":"🤔🤔","replyToPid":214063}
发表于 2019-9-24 20:39:49 来自手机 | 显示全部楼层
{"replyTo":"","text":"probably not. no leverage.","replyToPid":0}
发表于 2019-9-24 22:23:20 来自手机 | 显示全部楼层
{"replyTo":"","text":"You've got high and low gear after all, this is great","replyToPid":0}
发表于 2019-9-25 07:11:57 来自手机 | 显示全部楼层
{"replyTo":"","text":"ok I guess, but how is it locked in place","replyToPid":0}
发表于 2019-9-24 22:06:54 来自手机 | 显示全部楼层
{"replyTo":"","text":"better be the smoothest landing gear ever","replyToPid":0}
发表于 2019-9-24 23:03:43 来自手机 | 显示全部楼层
{"replyTo":"","text":"As long as the gearing is good","replyToPid":0}
发表于 2019-9-25 04:59:23 来自手机 | 显示全部楼层
发表于 2019-9-25 07:17:22 来自手机 | 显示全部楼层
{"replyTo":"","text":"If you keep it well greased it might work","replyToPid":0}
发表于 2019-9-25 07:20:22 来自手机 | 显示全部楼层
{"replyTo":"","text":"As long as there us some sort of brake so it doesn't work itself down but I like the idea.  I've pulled many custom trailers that had pneumatic landing gears that were independent of each other for leveling.","replyToPid":0}
GMT+8, 2026-4-19 14:14 , Processed in 0.077532 second(s), 24 queries .
