查看: 310|回复: 14
broke down again
 楼主| 发表于 2019-9-23 23:30:06 来自手机 | 显示全部楼层 |阅读模式
{"text":"im starting to think this company im working for is a joke. week ago broke down due a truck over heating was in that truck cause mine had a exhaust leak. now here i am in another truck doing my day in the city and my air brakes go out. well at least today im paid by the hour. is this pretty common for trucks to break down like this or does my company need some new trucks?","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-9-23 23:50:36 来自手机 | 显示全部楼层
{"replyTo":"","text":"Hahah","replyToPid":0}
发表于 2019-9-23 23:55:49 来自手机 | 显示全部楼层
{"replyTo":"","text":"No that's not common sounds like you company needs to do more prevent maintenance  and lot more regular services  more often","replyToPid":0}
发表于 2019-9-24 02:26:28 来自手机 | 显示全部楼层
{"replyTo":"","text":"Misty I would be looking for something else unless you could be put in a better running truck.  Good luck","replyToPid":0}
发表于 2019-9-24 00:10:30 来自手机 | 显示全部楼层
{"replyTo":"","text":"yeah, sounds like they need to find a better mechanic the service the trucks, are you need to find a better company to drive for. if you do flatbed, let me know. I'll give you a number to call. set your own schedule. home every weekend, or make money most weekends. the truck is inspected in my oil changed every 12,000 miles. I do 12,000 miles then I take a long weekend. have not had many issues of having to lose time, which is losing money, during those 12,000 miles.","replyToPid":0}
发表于 2019-9-24 08:57:46 来自手机 | 显示全部楼层
{"replyTo":"","text":"you getting the exhaust leak truck back? could just be using old trucks as a rental kinda thing. and how many miles on this truck? I just got mine last December and new with 400k the brake chambers could go out as they were original still so wasnt unexpectedly, the AC going out was but I had no history on the truck which sucks. best of luck and always good to keep eyes open","replyToPid":0}
 楼主| 发表于 2019-9-24 11:06:50 来自手机 | 显示全部楼层
{"replyTo":"","text":"thanks everyone. i appreciate it. i run dry van never did flat bed. would like to get a couple years in running dry van/reefer and than learn new trades. i have a couple companies that email me about work. this company has done nothing but lie to me. promised 3k miles a week. i only get 2k. every truck is run down breaking down. im trying to stick it out for 2 years so it seems good to other places but you all know you dont make money sitting on the side of the road unless your doing city. i only work city once or twice a month.","replyToPid":0}
发表于 2019-9-24 11:17:19 来自手机 | 显示全部楼层
发表于 2019-9-25 01:48:50 来自手机 | 显示全部楼层
{"replyTo":"","text":"it honestly sounds like YOU are doing a shitty job on your pre trip.  overheating is coolant brake lines are also pre trip. if i were your company id be askin why your not doing proper pre trip inspection and fire you cause those things are your responsibility","replyToPid":0}
 楼主| 发表于 2019-9-25 02:36:10 来自手机 | 显示全部楼层
770536 发表于 2019-09-24 17:48:50 it honestly sounds like YOU are doing a shitty job on your pre trip.  overheating is coolant brake lines are also pre trip. if i were your company id be askin why your not doing proper pre trip inspection and fire you cause those things are your responsibility
","text":"mr know it all. an fyi it over heated due to the water pump going out. i did my pre trip. maybe you should ask all the facts before making yourself look like a idiot. my company already stated that this had nothing to do with me. it was something they thought they had fixed. the shop should do their job a little better.","replyToPid":214168}
GMT+8, 2026-4-18 11:49 , Processed in 0.097342 second(s), 24 queries .
