查看: 464|回复: 10
I have a 2007 T680. I keep getting the park for 10min regin bs warning but I can’t get it to regin.
 楼主| 发表于 2019-9-23 12:03:48 来自手机 | 显示全部楼层 |阅读模式
{"text":"Would it work to  just manually bump my rpm up to whatever the regin rpm level is to clear the light? If so what rpm does it usually regin at.","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-9-24 17:12:44 来自手机 | 显示全部楼层
{"replyTo":"","text":"your blinker fluid is probably leaking into your muffler bearings","replyToPid":0}
发表于 2019-9-23 12:15:21 来自手机 | 显示全部楼层
{"replyTo":"","text":"take it to the shop","replyToPid":0}
发表于 2019-9-23 23:43:51 来自手机 | 显示全部楼层
{"replyTo":"","text":"your doser valve is probably plugged up","replyToPid":0}
发表于 2019-9-23 12:54:48 来自手机 | 显示全部楼层
456441 发表于 2019-09-23 04:52:36 I have even cycled gears and reset brakes
","text":"Check your def level sensor wire","replyToPid":213367}
发表于 2019-9-28 00:46:32 来自手机 | 显示全部楼层
{"replyTo":"","text":"nope you need to get the filter serviced","replyToPid":0}
发表于 2019-9-23 12:06:09 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"Unfortunately not.  Did you release brakes and reset then push regen button manually?"}
发表于 2019-9-23 12:30:33 来自手机 | 显示全部楼层
{"replyTo":"","text":"That usually fixes it too","replyToPid":213318}
发表于 2019-9-23 12:41:10 来自手机 | 显示全部楼层
{"replyTo":"","text":"its either that or take the chance of it going into derate because eventually it will","replyToPid":0}
 楼主| 发表于 2019-9-23 12:52:36 来自手机 | 显示全部楼层
817113 发表于 2019-09-23 04:06:09 Unfortunately not.  Did you release brakes and reset then push regen button manually?
","text":"I have even cycled gears and reset brakes","replyToPid":213308}
 楼主| 发表于 2019-9-25 09:12:27 来自手机 | 显示全部楼层
770536 发表于 2019-09-24 09:12:44 your blinker fluid is probably leaking into your muffler bearings
","text":"I didn’t even think about that you’re a genius. ","replyToPid":214007}
GMT+8, 2026-3-21 04:34 , Processed in 0.107661 second(s), 24 queries .
