查看: 126|回复: 10
How hard is it to be a flatbed trucker?
 楼主| 发表于 2019-9-23 04:41:10 来自手机 | 显示全部楼层 |阅读模式
{"text":"How much toll does it do to your body?  ","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-9-23 06:21:28 来自手机 | 显示全部楼层
{"replyTo":"","text":"Not as much toll as much a TRUCK STOP FOOD will do to your body .","replyToPid":0}
发表于 2019-9-23 22:38:55 来自手机 | 显示全部楼层
{"replyTo":"","text":"on top of a load tarpping in the ice and cold can be a pain.  especially if there is wind.","replyToPid":0}
发表于 2019-9-23 13:52:27 来自手机 | 显示全部楼层
{"replyTo":"","text":"Not much mostly is fast loading and unloading strapping or chaining is not taking much. not like waiting for hours to load or unload if you drive dry van.\nTarping is taking little longer like an hour to two if you have a big load. and make sure you can lift the tarps they are heavy 100lbs.","replyToPid":0}
发表于 2019-9-23 18:45:23 来自手机 | 显示全部楼层
{"replyTo":"","text":"heavy lifting of tarps dragging around chains throwing straps out in the heat slot more more costly if your an owner operator","replyToPid":0}
发表于 2019-9-23 21:34:45 来自手机 | 显示全部楼层
{"replyTo":"","text":"You’ll make better money as owner operator pulling a flatbed... especially if you do oversized ","replyToPid":0}
发表于 2019-9-24 09:18:36 来自手机 | 显示全部楼层
{"replyTo":"","text":"It gets easier overtime. Physically at least It’s more of a mental game ","replyToPid":0}
发表于 2019-9-24 09:21:00 来自手机 | 显示全部楼层
23589 发表于 2019-09-23 14:38:55 on top of a load tarpping in the ice and cold can be a pain.  especially if there is wind.
","text":"That and the other extreme in which it’s super hot and humid trying to do the same. ","replyToPid":213587}
发表于 2019-9-24 09:24:23 来自手机 | 显示全部楼层
{"replyTo":"","text":"I think you should just go for it though instead of asking for a excuse to not try it. Just go for it if it works it works if not you can go back to being a lazy van driver lol ","replyToPid":0}
发表于 2019-9-24 09:27:32 来自手机 | 显示全部楼层
{"replyTo":"","text":"It did a number on me I sold my flatbed went to hopper bottom easy on the body ","replyToPid":0}
GMT+8, 2026-2-11 17:36 , Processed in 0.055456 second(s), 24 queries .
