查看: 98|回复: 7
Any Help
 楼主| 发表于 2019-9-23 00:50:21 来自手机 | 显示全部楼层 |阅读模式
{"text":"ABS trailer on, I didn't find the reason. Any help here?","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-9-23 01:38:47 来自手机 | 显示全部楼层
{"replyTo":"","text":"Also check your pigtail and the prongs, if they're split prongs spread them a bit to make sure there's a good connection.","replyToPid":0}
发表于 2019-9-23 02:46:11 来自手机 | 显示全部楼层
{"replyTo":"","text":"wiggle your pigtail. if it goes off put some dielectric grease on it until you can replace it","replyToPid":0}
发表于 2019-9-23 01:21:17 来自手机 | 显示全部楼层
{"replyTo":"","text":"Check under the trailer where the Abs wire is connected to the wheel, one of the wires is probably unplugged.","replyToPid":0}
发表于 2019-9-23 12:16:41 来自手机 | 显示全部楼层
{"replyTo":"","text":"check the sensors for oms also check the exits for the sensors for 5volts.\nif you don't get any oms on the sensor it means is a sensor if you are not getting 5volts at the exits poles at the box it means is the harness for the abs.","replyToPid":0}
发表于 2019-9-23 12:17:41 来自手机 | 显示全部楼层
{"replyTo":"","text":"Fuse or pig tail.  If light blinks its the pig tail.","replyToPid":0}
发表于 2019-9-23 18:33:07 来自手机 | 显示全部楼层
{"replyTo":"","text":"Cut the wire!!","replyToPid":0}
发表于 2019-9-23 18:33:00 来自手机 | 显示全部楼层
{"replyTo":"","text":"Cut the damn wire!!","replyToPid":0}
GMT+8, 2026-2-9 03:20 , Processed in 0.058839 second(s), 24 queries .
