查看: 626|回复: 31
My brand new 2020 😒
 楼主| 发表于 2019-9-22 06:02:53 来自手机 | 显示全部楼层 |阅读模式
{"text":"So these lights came on today as I was going down 20. Still on after I disconnected from trailer. Oh and the icing on the cake, went to use my microwave today. Turned on the inverter, plugged it in and the plugs dont even work. So my brand new truck that I got with 37 miles on it.  Took my 1st load with it Wednesday now has 1,635 miles on and will have to go into the shop. 👎😱😂","videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":2560.0,\"name\":\"\",\"url\":\"\",\"width\":1920.0},{\"description\":\"\",\"height\":2560.0,\"name\":\"\",\"url\":\"\",\"width\":1920.0}]","canComment":true}
发表于 2019-9-22 07:52:57 来自手机 | 显示全部楼层
{"replyTo":"","text":"they don't build anything like they used to that's for sure","replyToPid":0}
发表于 2019-9-22 06:57:08 来自手机 | 显示全部楼层
{"replyTo":"","text":"they had to reprogram the parameters and change some kind of computer board took all day","replyToPid":0}
发表于 2019-9-22 06:40:48 来自手机 | 显示全部楼层
{"replyTo":"","text":"that's a traction control and stability control light n adaptive cruise control same thing happened to my 2020 there's a little box it says wert it turns on your power inverter it's on the left side of your bunk","replyToPid":0}
 楼主| 发表于 2019-9-23 09:39:29 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"😂😂 I am a black woman raised in the South. You will have to try a helluva lot harder to get a rise out of me. I gave you an upvote for the effort tho. Thanks for stopping by 😘"}
发表于 2019-12-8 03:03:48 来自手机 | 显示全部楼层
{"replyTo":"","text":"yup figures you can't go wrong with PACKARD Kenworth and Peterbilt are the only way to go!","replyToPid":0}
发表于 2019-12-8 00:43:03 来自手机 | 显示全部楼层
{"replyTo":"","text":"must be an International lol","replyToPid":0}
发表于 2019-9-30 04:53:45 来自手机 | 显示全部楼层
255590 发表于 2019-09-29 11:56:08 what was the issue? i hope you're back up and running.
","text":"I got running soon as a pulled over on shoulder,  I just turned it off and restarted it, everything had been fine since. I'll write it up when I get back to the terminal.","replyToPid":217281}
发表于 2019-9-26 01:33:17 来自手机 | 显示全部楼层
{"replyTo":"","text":"my brand new 2020 shut off east bound 40 before Flagstaff,  had to coast to side of the road and re start it","replyToPid":0}
发表于 2019-9-22 07:00:10 来自手机 | 显示全部楼层
655774 发表于 2019-09-21 22:57:08 they had to reprogram the parameters and change some kind of computer board took all day
","text":"I'm not happy with the 2020 want my old truck back 2016 cascadia 10 speed don't like automatics","replyToPid":212516}
发表于 2019-9-22 08:17:16 来自手机 | 显示全部楼层
612134 发表于 2019-09-21 23:32:57 just out of curiosity, what kind of tractor is this?
","text":"The dash looks like my 2019 Cascadia.  I have electrical problems, too, that I think are related to the bunk heater.  When I shut off the truck the four-ways come on.  Even if I turn off the battery they still blink!  I think the bunk heater got word in wrong.  Of yes, to use the bunk heater I have to turn on an interior light.","replyToPid":212531}
 楼主| 发表于 2019-9-22 06:51:02 来自手机 | 显示全部楼层
655774 发表于 2019-09-21 22:40:48 that's a traction control and stability control light n adaptive cruise control same thing happened to my 2020 there's a little box it says wert it turns on your power inverter it's on the left side of your bunk
","text":"Yea my alerts told me about the lights. Just not why they are still on. Yes my inverter is turned on. But the plugs dont work. I had 14.2 volts when I tried all 3 outlets 😭😭😞","replyToPid":212510}
发表于 2019-9-22 07:32:57 来自手机 | 显示全部楼层
{"replyTo":"","text":"just out of curiosity, what kind of tractor is this?","replyToPid":0}
发表于 2019-9-22 08:29:30 来自手机 | 显示全部楼层
{"replyTo":"","text":"that sux","replyToPid":0}
发表于 2019-9-22 08:43:53 来自手机 | 显示全部楼层
{"replyTo":"","text":"its electrical sensor problem. dont let the shop confuse you and make you pay a leg and arm. my 2019 cascadia had the same issue","replyToPid":0}
GMT+8, 2026-4-19 15:48 , Processed in 0.097427 second(s), 24 queries .
