查看: 596|回复: 0
2010 PEterbilt 386
 楼主| 发表于 2019-9-22 05:06:18 来自手机 | 显示全部楼层 |阅读模式
Hide Access Link: https://prd-forum-api.truckerpath.com/v6/direct_link/?actionCode=AccessTruckAndJobAction&pk=9e39462816d55a59644&token=57e33c9c4854d842a5c609d97b3f1db7
mileageV2: 786623
horsePowerV2: 550
engineManufacturerV2: Cummins
engineTypeV2: Isx
engineTireV2: USA Tier 4 Final
engineBrakeV2: 1
engineOverhaulV2: 2
turboV2: 1
transmissionRebuiltV2: 2
transmissionTypeV2: Manual
numberofSpeedV2: 13 Spd
ratioV2: 3.55
differentialLockV2: 1
suspensionV2: Flex Air
numberofRearAxlesV2: Tandem
colorV2: White
tiresV2: 11r 22.5
wheelsV2: All Aluminum
wheelbaseV2: 244
aCConditionV2: Excellent
aCV2: 1
powerLocksV2: 2
sleeperV2: 1
sleeperTypeV2: Mid Roof Sleeper
numberofBedsV2: 1
refrigeratorV2: 1
aPUV2: 2
gliderKitV2: 2
headcheRackV2: 2
wetKitV2: 2
categoryOldV2: 3.8
zipcodeV2: 42039
cityV2: Fancy Farm
stateV2: KY
condV2: Used
emailV2: Mballard85@outlook.com
makemodelV2: PETERBILT 386
phonenoV2: 2705563225
priceV2: 28000
stocknoV2: 9383
latitudeV2: 36.75
longitudeV2: -88.79000000000001
modelyearV2: 2010
fuelTypeV2: Diesel
treadDepthV2: New drives
{"text":"I have a 2010 Peterbilt 386 has 784,000 will go up a little bit until I pick up my new truck. Truck has a Cummins isx has been tuned to 550 HP and 1850 torque. Has a Eaton 13 speed with 3.55 rears 244 inch wheel base. Truck has had oil changed every 15,000 miles. Truck has had many new parts king pins recently replaced muffler been replaced steering sector, air dryer, torque rods, new radiator, New oil pan gasket,90% brakes on front 50% on back 50% steer tires 90% drive tires all are 11r 22.5. All leaf spring bushings have been replaced new shocks front and rear. the cam was replaced. before I bought the truck the dealership replaced egr cooler,turbo, and dpf filter. Just had an oil sample run and came back clean! Apu and wet kit not sold with truck.","videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":620.0,\"name\":\"\",\"url\":\"\",\"width\":828.0},{\"description\":\"\",\"height\":620.0,\"name\":\"\",\"url\":\"\",\"width\":828.0},{\"description\":\"\",\"height\":620.0,\"name\":\"\",\"url\":\"\",\"width\":828.0},{\"description\":\"\",\"height\":620.0,\"name\":\"\",\"url\":\"\",\"width\":828.0},{\"description\":\"\",\"height\":620.0,\"name\":\"\",\"url\":\"\",\"width\":828.0},{\"description\":\"\",\"height\":620.0,\"name\":\"\",\"url\":\"\",\"width\":828.0},{\"description\":\"\",\"height\":620.0,\"name\":\"\",\"url\":\"\",\"width\":828.0},{\"description\":\"\",\"height\":620.0,\"name\":\"\",\"url\":\"\",\"width\":828.0},{\"description\":\"\",\"height\":1104.0,\"name\":\"\",\"url\":\"\",\"width\":828.0},{\"description\":\"\",\"height\":620.0,\"name\":\"\",\"url\":\"\",\"width\":828.0},{\"description\":\"\",\"height\":620.0,\"name\":\"\",\"url\":\"\",\"width\":828.0},{\"description\":\"\",\"height\":620.0,\"name\":\"\",\"url\":\"\",\"width\":828.0},{\"description\":\"\",\"height\":620.0,\"name\":\"\",\"url\":\"\",\"width\":828.0},{\"description\":\"\",\"height\":620.0,\"name\":\"\",\"url\":\"\",\"width\":828.0},{\"description\":\"\",\"height\":1104.0,\"name\":\"\",\"url\":\"\",\"width\":828.0},{\"description\":\"\",\"height\":1104.0,\"name\":\"\",\"url\":\"\",\"width\":828.0}]","canComment":null}
GMT+8, 2026-4-2 16:55 , Processed in 0.071878 second(s), 25 queries .
