查看: 523|回复: 22
Quick question
 楼主| 发表于 2019-9-21 08:19:58 来自手机 | 显示全部楼层 |阅读模式
{"text":"Can anyone tell me if you have to stop at a weight station if you are running bobtail","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-9-21 11:31:11 来自手机 | 显示全部楼层
{"replyTo":"","text":"Ummm how is an officer at a scale gonna know youre on PC unless you stop? if youre in a commercial vehicle you should always stop at a scale unless PrePass gives you a green light, whether you're on PC or not","replyToPid":0}
 楼主| 发表于 2019-9-21 21:13:46 来自手机 | 显示全部楼层
{"replyTo":"","text":"Thanks to all those who took time out to answer. It was my 1st bobtail so I didn't know for sure","replyToPid":0}
发表于 2019-9-23 12:18:28 来自手机 | 显示全部楼层
{"replyTo":"","text":"It’s always a good practice to just go through the scale cause you’re still operating a commercial vehicle. Yeah you could argue that you’re using PC but is it really worth the trouble of risking a pissed off dot officer to pull you over? ","replyToPid":0}
发表于 2019-9-21 12:03:39 来自手机 | 显示全部楼层
{"replyTo":"","text":"yes, because they can pull over to ask u your e log book.","replyToPid":0}
发表于 2019-9-23 12:27:31 来自手机 | 显示全部楼层
612134 发表于 2019-09-21 05:43:47 weigh stations are not just for trailer weight and trailer inspection. they're for tractor and or trailer weight and inspections also all inspection of all eld duties off on or pct
","text":"Trucker Path Moderators should take test.","replyToPid":212060}
发表于 2019-9-23 12:25:33 来自手机 | 显示全部楼层
Yes if you’re on duty driving and no if you’re using PC.
{"replyToPid":211972,"replyTo":"
599477 发表于 2019-09-21 02:13:22 Yes if you’re on duty driving and no if you’re using PC.
","text":"And you call yourself a moderator. What a dumb fucker."}
发表于 2019-9-23 12:59:28 来自手机 | 显示全部楼层
759990 发表于 2019-09-21 13:13:46 Thanks to all those who took time out to answer. It was my 1st bobtail so I didn't know for sure
","text":"Then you shouldn't be driving.","replyToPid":212134}
发表于 2019-9-21 10:13:22 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"Yes if you’re on duty driving and no if you’re using PC. \n\nEdit:I’m sorry, I was very wrong. I’ve never driven bobtail past a weight station while not On Duty driving. "}
发表于 2019-9-21 13:43:47 来自手机 | 显示全部楼层
{"replyTo":"","text":"weigh stations are not just for trailer weight and trailer inspection. they're for tractor and or trailer weight and inspections also all inspection of all eld duties off on or pct","replyToPid":0}
禁止发言
发表于 2019-9-23 12:32:29 来自手机 | 显示全部楼层
GMT+8, 2026-4-17 19:44 , Processed in 0.096760 second(s), 24 queries .
