查看: 659|回复: 13
can any one knows what going on with this truck?..I can't putting in gear no diesel power...dead then shut off
 楼主| 发表于 2019-9-21 01:34:23 来自手机 | 显示全部楼层 |阅读模式
{"text":"","videos":"[{\"url\":\"http://d2w8udw005hdju.cloudfront.net/video/151807/android_753216_1569000732305.mp4\"}]","link":"{}","pics":"[{\"description\":\"\",\"height\":607.0,\"name\":\"\",\"url\":\"\",\"width\":1080.0}]","canComment":true}
发表于 2019-12-24 10:28:12 来自手机 | 显示全部楼层
753216 发表于 2019-09-20 17:35:19 2013 cascadia DD15 With eaton 10 speed
","text":"spark plugs are probably corroded, sounds like you're flooding it","replyToPid":211791}
发表于 2019-9-21 03:17:24 来自手机 | 显示全部楼层
{"replyTo":"","text":"Sorry to be the one to break it to you, but 2013 dd15 has caused people to lose their homes, marriages, strong men to cry, etc.  It's time to chunk it n move on.","replyToPid":0}
发表于 2019-9-21 03:54:44 来自手机 | 显示全部楼层
{"replyTo":"","text":"Fuel filter good ,, check fluids oil antifreeze, check wire on engine , check fuses , if al is good ,then I would say if not a censor on engine then injection system, good luck","replyToPid":0}
发表于 2019-9-21 08:19:13 来自手机 | 显示全部楼层
{"replyTo":"","text":"check the gas pedal!!! it may be the problem","replyToPid":0}
发表于 2019-9-21 02:20:11 来自手机 | 显示全部楼层
{"replyTo":"","text":"its broke","replyToPid":0}
发表于 2019-9-21 02:58:31 来自手机 | 显示全部楼层
{"replyTo":"","text":"Almost sounds like it’s flooding. \n\nPossible injectors are worn","replyToPid":0}
 楼主| 发表于 2019-9-21 01:35:19 来自手机 | 显示全部楼层
{"replyTo":"","text":"2013 cascadia DD15 With eaton 10 speed","replyToPid":0}
发表于 2019-9-21 02:07:38 来自手机 | 显示全部楼层
{"replyTo":"","text":"are you serious or just joking around???","replyToPid":0}
发表于 2019-12-20 23:17:03 来自手机 | 显示全部楼层
{"replyTo":"","text":"was it actually idling?","replyToPid":0}
发表于 2019-12-21 16:27:40 来自手机 | 显示全部楼层
723808 发表于 2019-09-20 19:17:24 Sorry to be the one to break it to you, but 2013 dd15 has caused people to lose their homes, marriages, strong men to cry, etc.  It's time to chunk it n move on.
","text":"I wouldn't say that.... that's what I've got and she's been a great running truck.  I love mine...I'm happy I bought her.  😜","replyToPid":211834}
GMT+8, 2026-4-17 08:04 , Processed in 0.164834 second(s), 24 queries .
