查看: 28|回复: 2
Parking problems
 楼主| 发表于 2019-9-19 03:11:30 来自手机 | 显示全部楼层 |阅读模式
{"text":"I just want to know when the industry is going to address the problem of not enough parking for trucks. This has been a long time issue since way before I started in 2004 and it isn't getting any better, it's much worse, more trucks on the road and still not enough parking. you would think that these truckstops would figure out that bigger parking lots = more revenue simply because more people can use the facilities, more rest areas instead of closing them even if it is just changed into truck parking only. and pay to park truckstops should be ashamed of themselves, there is nothing about them that make them any better, definitely no more secure than the rest. ok my rant is done lol see what Chicago does to you. ","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-9-19 03:28:26 来自手机 | 显示全部楼层
{"replyTo":"","text":"Anything that’s has to do with doing something for the truckers benefit will be the last thing talk about by those who determine what good for trucker .and if it has to do with money then it definitely is not being talked about UNLESS it has to do with extorting more money out of truckers","replyToPid":0}
发表于 2019-9-19 03:52:12 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"Why build parking lots when they can give tickets for parking on the streets or on the ramps? "}
GMT+8, 2026-2-11 07:13 , Processed in 0.090501 second(s), 23 queries .
