查看: 118|回复: 3
Only in Adel, GA. This lazy ass XPO driver went through the drive thru at Wendy’s
 楼主| 发表于 2019-9-18 11:33:08 来自手机 | 显示全部楼层 |阅读模式
发表于 2019-9-18 16:02:41 来自手机 | 显示全部楼层
{"replyTo":"","text":"Well Ms Pissy Pants, depending on what time it is, he may not have been able to go inside. After a certain time the lobby doors lock for robbery risk, and you can’t walk through the drive thru because there’s no license plate to ID after a robbery if you run into the woods. I’ve bob tailed a full sleeper through a McDonald’s drive thru by the fairburn travel plaza on 85 south of Atlanta because they wouldn’t serve me even after I offered my Drivers license. ","replyToPid":0}
发表于 2019-9-19 07:29:53 来自手机 | 显示全部楼层
{"replyTo":"","text":"who cares. lobby is probably closed. good on him for making work.","replyToPid":0}
发表于 2019-9-18 15:35:42 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"With the height and size differences, it actually looks like a lot more work than just walking 😆"}
GMT+8, 2026-4-18 18:43 , Processed in 0.278099 second(s), 24 queries .
